Lift motor to install headers?
Installation instructions note that the engine needs to be lifted to install, is there any way to install w/o taking motor mounts loose. Also notes to install from the top, can headers be installed from the bottom?
Just wanted some extra advice before I get started.
driver's side need to remove oil filter, coolant sensor on the head, and steering shaft.
pass side, remove the starter. also, for a little more room, remove the clutch inspection shield
lastly, my advice is to fit the header/gasket on the head with the bolts to make sure they line up before lowering the enigine back down. it'll save you a lot of time later. ask me how i know
hope this helps.. PM me if you need more info
but in the instructions i've read I've never heard of such a thing.
http://www.ls1howto.com/index.php?article=29
I loosened the top motor mount nuts and lifted the motor up until the intake just touched under the cowl. Only take one side off at a time. Loosen the opposite side but don't remove the nut.
You will have to remove the coil packs but I left the valve covers on and didn't have any trouble. You will have to take the alternator out and remove the streering shaft but that is no big deal either. Getting to the manifold bolts in the back on the driver's side is a little bit of a pain. The headers drop in from the top. I had a buddy down below guiding the collectors past and obstructions. Once their in the fit is superb - they clear everything - wires, filter, starter, everything is well away from the pipes.
Would do it again in a second.
Also, be real careful when you reinstall the bolts in the heads. The aluminum is real soft and it would be easily to cross thread a bolt. Does that sound like I have had experience.
Good Luck and Go For It!
Good tips. The same goes for mine too. They went in from the top after the engine was raised one side at a time. One other caution I would recommend you really pay attention to and that is: DO NOT TURN THE STEERING WHEEL WITH THE COUPLING BOLT/CLAMP DISCONNECTED! a very slight amount of movement is OK but you are asking for expensive problems if you allow the wheel to rotate too far. If you still have a functioning steering column lock, no worries. Leave it locked until you finish the driver's side and the clamp is re-connected. If you have a CLB installed, and the steering wheel will not lock, I would recommend tying off the wheel with rope if necessary. The steering wheel position sensor can be affected if the wheel is allowed to be turned while disconnected. HTH
Can,t wait to hear the roar!!!!!!!!!!!!!!!
with EStreeter right on. 2. yes, top
valve cover off on the pass. side helps
also the clutch insp cover removed for the pass side if a must do
driver's side disconnect the ground near the rear of the block, one wire goes to the harness the other is a braided ground strap
and follow the instructions for the starter and steering shaft removal
the deal w/ not turning the steering is the clock spring, which fires the air bag
