free mods
Old Oct 7, 2005 | 03:52 AM
C5Generl's Avatar
C5Generl
Default free mods
anyone have a list of all the free mods i can do to my car - '02 c5 mn6?
Old Oct 7, 2005 | 04:05 AM
EHS's Avatar
EHS
Sorry, no.
Old Oct 7, 2005 | 06:43 AM
Jserman's Avatar
Jserman
free modes.. it is a corvette nothing is free on this thing....
Old Oct 7, 2005 | 07:20 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Lower it
Cold Air mod
Ziptie Mod (stock airbox)
Throttle Body bypass (not quite free but under $10)
Old Oct 7, 2005 | 11:05 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Originally Posted by EnglandGreen
Lower it
Cold Air mod
Old Oct 7, 2005 | 11:17 AM
Mike Mercury's Avatar
Mike Mercury
free???
here's one:
http://mikemercury.home.att.net/precats.htm
Old Oct 7, 2005 | 11:42 AM
b98's Avatar
b98
Originally Posted by Mike Mercury
Thanks good info.
Old Oct 7, 2005 | 02:08 PM
allaboutdaz's Avatar
allaboutdaz
any more?
Old Oct 7, 2005 | 08:08 PM
Jserman's Avatar
Jserman
what gains can you get bye cutting out the precats????
Old Oct 7, 2005 | 08:22 PM
Mike Mercury
all my mods:
bone stock A4 except:
*3.42 rear axle ratio
*K&N OEM air filter
*Z06 airlid
*Predator tuning
*Z06 titanium cat-backs
*and gutting the pre-cats
Old Oct 8, 2005 | 05:51 PM
billjax's Avatar
billjax
St. Jude Contributor
Good numbers, Mike! I was going to ask what ratio you changed from but I went your site and got all the info! Nice job on the site and I really enjoyed your Corvette history!!
Old Oct 8, 2005 | 11:59 PM
debmwb's Avatar
debmwb
Any emission issues from gutting the pre-cats (inspection wise)? Does Ohio use sniffers?
Old Oct 9, 2005 | 01:06 PM
C5Generl's Avatar
C5Generl
how much can be gained by gutting the pre cats?
Old Oct 12, 2005 | 04:06 PM
MR '02's Avatar
MR '02
Interested ??? Anyone ??????
Old Oct 12, 2005 | 04:15 PM
C5 ChemE's Avatar
C5 ChemE
all my mods:
*K&N OEM air filter
*Z06 airlid
*Predator tuning
I think you're being a little misleading- with a 60' time like that, you must be using Drag Radials, right?. An ET like that could be acheived with a STOCK car on DRs!
Old Oct 12, 2005 | 09:03 PM
MikeTennent's Avatar
MikeTennent
Default Beware of C5Generl...
I purchased a Predator which he said was unlocked. 1st time I attempted to use it, I got the dreaded message, "Locked to another vehicle." He does not respond to my emails.
Old Oct 12, 2005 | 09:13 PM
debmwb's Avatar
debmwb
Given a properly prepared track, a good driver, and a good vette, that time is definitely possible on street tires! I'd expect a 60' time on DR's to be in the 1.6-1.7 range.
To free mods
Old Oct 12, 2005 | 09:19 PM
Mike Mercury
Never confuse me with a Mustang owner
my mods list is 100% accurate.
Bone stock I was running consistant 13.3's at the dragstrip.
The 3.42's, gutted precats, Z06 titanium cat-backs, better launching techniques, and Predator tuning got me down into the high 12's. I ran back to back 12.9x. It was a 65 degree evening with great surface prep.
6 months later - with 88 degree heat and 79% humidity - my fastest was 13.06 with 60' times in the 2.0x
User 81424's Avatar
User 81424
Weight reduction
You can achieve substantial weight reduction with the following modifications, while still having a car that's very comfortable to drive. Most of these modifications will directly increase (and decrease in a few cases) the safety of the car, while safety is indirectly improved due to the better handling and limits of a lighter car. Fighter pilots say "speed is life". Acceleration, deceleration, and lateral acceleration are all forms of acceleration, and lighter cars accelerate better in each of these ways because the tires have less mass to control....thus a lighter car is a safer car. Lighter cars have better moments of inertia which allows them to turn in more easily and roll less. Lighter cars are also easier on the tires and gas.
All the stage weight estimates are typically wild butt guesses, but it makes it easy to see what is possible. The weight listings in the separate weight posting is MUCH more reliable.
Stage I: Streetable weight reduction mods
Non-popup headlights (~40 lbs)
Braking rotors with an aluminum hat, or titanium rotors (unproven on street cars) (~20-30 lbs)
Carbon fiber hood (~12 lbs)
Z06 (thinner) windshield and side windows (~5.7 lbs)
Non runflat tires (~20 lbs)
Slicks (~30 lbs)
Z06 wheels (~4 lbs est.)
Corsa titanium exhaust (~35 lbs)
Long tube headers (~20 lbs)
Halltech aluminum alternator & bracket (10 lbs)
Carbon fiber driveshaft (~2 lbs)
Newer torque tube
Less options [HUD, elec AC, Active Stability, seat/mirror/steering wheel memory, cd changer] (~50 lbs)
Less gasoline & wiper fluid (No wiper fluid=9lbs, 6 lbs for every gallon of gas in that 18 gallon tank....~81 lbs for autocrossing)
Remove cargo net
Remove targa top (~20 lbs)
Remove BCM’s
Remove C5 "appearance mods" - exhaust plates, doorsill covers, etc.
Remove fuel rail covers
Replace stock crank pulley with aluminum aftermarket pulley
Replace steel dampener with aluminum dampener
Replace stock targa top with lexan piece (coupes)
Replace water pump with electric water pump
Replace battery with smaller battery
Replace non-stressed fasteners with aluminum or titanium fasteners
Replace leaf springs with coil over shocks with titanium springs
Replace steel shifter with aluminum shifter and delrin or titanium shift ****
Remove all loose change, CD's, golf clubs, misc. items, from center console, hatch area, and glove box
Empty your pockets of extra change, PDA's, cell phones, keys, lead plates, or whatever other junk you lug around
Go on a diet =p
Stage II: Hardcore semi-streetable weight reduction mods
Aluminum flywheel (~10 lbs)
Lighter clutch like Exedy or Quartermaster (~10 lbs)
Racing buckets (40-50 lbs)
Remove tire repair kit (Z06)
Off-road x-pipe (10 lbs)
Remove floor mats
Remove fog lights
Replace stock hood, fenders, doors, roof, hatch and bumpers with aftermarket carbon fiber pieces
Stage III: Track only weight reduction mods
Racing steering wheel & delete both airbags (~30 lbs, but get a 4-6 point harness)
Use unpadded aluminum or carbon fiber steering wheel
Run open headers
Remove column locking hardware
Remove interior – passenger seat, carpets, speaker panels, head liner, dash, center console, glove box, door panels, sun visors, rear view mirror, insulation, etc.
Remove A/C Compressor
Remove A/C controls and ducting
Remove AIR pump system
Remove factory radio, speakers, and/or CD changer, and unnecessary wiring
Remove HUD projector
Remove windshield wiper fluid reservoir and pump
Remove windshield wipers and motors
Remove stock cat back
Remove power steering pump
Remove front sway bar (drag only)
Remove ABS, TC, AH hardware and sensors (drag only)
Remove fender wells
Remove headlight assembly, turn signals, taillights and reflectors
Remove/shave side mirrors
Remove torque tunnel cover
Remove seat belts
Remove parking brake
Remove side windows and motors
Remove power locks and power windows
Remove side impact beams
Replace stock front and rear glass with polycarbonate “glass”
Rebuild motor with Al or Ti connecting rods, Ti valve spring retainers and pushrods
Port the heads
Remove all flashing from the engine, then polish
Replace valve covers with magnesium or carbon fiber parts
Strip entire car, acid wash chassis, put car back together.
Reducing unsprung weight—not all is streetable
Replace stock wheels with forged 1-piece wheels
Use 3-piece wheels by Jongbloed, Kodiak, CCW, BBS
Skinny front wheels (drag only)
Use Ti fasteners on 3-piece wheels (~1 lbs per wheel)
Use lighter non-runflat tires, or even Hoosier nylon corded slicks
Use lighter calipers
Replace stock rotors with 2-piece, unvented or titanium rotors
Replace wheels studs with titanium studs
Replace lug nuts with aluminum or titanium lug nuts
Remove tire pressure sensors
Use rubber valve stem without a cap
Balance the wheels without tires or balancing weights, and then mount tires
Old Oct 12, 2005 | 09:40 PM
killaz's Avatar
killaz
what is the free lowering mod
