I have a set of Bob's 18x12 Z06's with 335/30's on them, and I noticed that I am rubbing the inner fender well pretty bad on the passenger side and just a bit on the drivers side. I have had these on all summer long with no problems and in the past few days I have noticed this. The car is only lowered about 3/4 of an inch. Could the rear shocks be going out? The car is an 02 coupe with 21k on it. It seems as if they rub when I hit a bump and pull out of me driveway.
Thanks for any suggestions.
Check your tire pressure. If its cooler it is probably low and could also be from sitting. Lower pressure will alow tire sway and may be enough to cause the problem.
Went to the dealer, and had the camber checked, as well as the rear shocks, everything back there checked out okay, I've had the tires filled with nitrogen since this spring and the pressure never changes. On the way home I didnt hear any rubbing at all, maybe it was just one of those things! I'll work on getting some pics.
