1st & 2nd gear having problems engaging
It only happens when the vette is at a complete stop and I try to put it into 1st gear and it will not engage. I've gotten pretty good at knowing when it hasn't engaged because initially I wouldn't realize it was fully in 1st gear and it would pop out. The only way to get it into first when this is happening is to put it into a different gear first (say 2nd), let out the clutch slightly and then try to put it back into 1st and it will usually go.
I used to be able to just put it into 2nd gear, however now 2nd gear is experiencing the same problem as 1st! I think this is because I had taken to starting in 2nd gear since 1st was giving me so much trouble. Now I have to put it in one of the other gears briefly to get 1st or 2nd to engage fully.
My initial guess is there is a problem with the synchros for 1st and 2nd. Car is still under extended warranty and it's at the dealer ship now. However they just called back and are trying to tell me this is a problem with my clutch!!! Which conveniently is not covered under warranty of course. I fail to understand how the clutch would be responsible for 1st and 2nd not engaging, but yet not cause problems with engaging any other gears.
Any help would be appreciated.
Anybody tell us what's wrong???
