New Battery Time
Old Oct 19, 2005 | 03:52 AM
GrayC5's Avatar
GrayC5
Originally Posted by rws.1
I went to Sam's today and they claim they don't carry and can't order the Orbital. they do have the gel mat marine version (Stowaway) for $129.
That may be because at Sam's they're sold under the NASCAR® Branded Product Line made exclusively for Sam's by Exide:
Exide Introduces NASCAR® Branded Product Line at #1 Warehouse Club
I have found that not all Sam's Clubs carry the same products, but have them look for the following: NASCAR XLT XDT34 and NASCAR XLT XDT35. I believe these are the numbers for which they should be looking, but I'm not totally certain. They should also be able to look up the specs for you. Also, these batteries are pretty distinctive looking in that they are made with the 3 pairs (for a total of 6) of cylindrical cells that look just like the Exide Select Orbital Series batteries and similar to the Optimas. Too, you can go to http://www.samsclub.com/ and do a search on XDT34 and XDT35 and this should bring these batteries up for you to see.
Also just as added information, according to their respective web site, the Optima Red Top and Yellow Top and the Exide Select Orbital® and Exide Select Orbital® XCD batteries are all Absorbent Glass Mat (AGM) batteries, not gel cell. There is a difference:
"All you ever wanted to know about AGM and Gel Cell batteries".
Hope this helps.
UPDATE: Just returned from Sam's a short while ago and NASCAR XLT XDT34 and NASCAR XLT XDT35 are the correct numbers for the Exide Select Orbital Series batteries sold by Sam's under their NASCAR® Branded Product Line. The label on top of these batteries has a small "Orbital" logo on it and there is a red label on the side of the battery that says "non-spillable".
Old Oct 19, 2005 | 04:51 PM
6 speed Sid's Avatar
6 speed Sid
Some have had problems, but my Red-Top has been fine.
Old Oct 19, 2005 | 06:33 PM
SGT. PYLE's Avatar
SGT. PYLE
Well, I broke down and got an Optima Red Top 75/35. Fit is great, looks great and best of all no more worry about leaking on the PCM.
Old Oct 19, 2005 | 07:31 PM
Sicvette's Avatar
Sicvette
I just bought my optima red top and the car feels much smoother than when I had the Delco in. Very pleased with the results but alot of green for a battery.
Old Oct 19, 2005 | 08:27 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Originally Posted by GUSTO14
Another option is the Orbital, by Exide. It's a pretty conventional looking battery and costs about the same as an Optima.
GUSTO
Old Oct 19, 2005 | 08:45 PM
50th year's Avatar
50th year
2017 C7 of Year Finalist
I decided on the excide. I ordered one on ebay yesterday. 92 bucks plus shipping.
Ron
Old Oct 19, 2005 | 09:59 PM
GrayC5's Avatar
GrayC5
Default Update to previous post above.
Re: My previous post above.
Just returned from Sam's a short while ago and NASCAR XLT XDT34 and NASCAR XLT XDT35 are the correct numbers for the Exide Select Orbital Series batteries sold by Sam's under their NASCAR® Branded Product Line made exclusively for them by Exide. The label on top of these batteries has a small "Orbital" logo on it and there is a red label on the side of the battery that says "non-spillable".
Old Oct 19, 2005 | 10:11 PM
B777's Avatar
B777
Cruising
Originally Posted by screw991le
Just put in an Orbital last week in my 2001 coupe. Fits nice and got it for $108 from Napa. 770 CCA!
Old Oct 20, 2005 | 03:12 AM
skeet's Avatar
skeet
Always used Red Tops in my C4's and now put one in my 02 Z06. Someone posted their Red Top exploded? How can that be possible with a dry cell battery????
Old Oct 20, 2005 | 02:43 PM
GrayC5's Avatar
GrayC5
Contrary to what you may have read on this Forum, Optima Red Top and Yellow Top and also the Exide Select Orbital® and Exide Select Orbital® XCD batteries are NOT dry cell batteries. Also, they are NOT Gel cell batteries. According to their respective web sites they are all Absorbent Glass Mat (AGM) batteries. AGM batteries use a liquid acid electrolyte and like other lead acid batteries, they can at times emit explosive gas. The difference is that in the AGM batteries the acid electrolyte is absorbed in the glass mat which makes them less likely to leak.
Old Oct 20, 2005 | 03:52 PM
craig04c5's Avatar
craig04c5
Is the stock battery in an 04 Gel Cell or AGM?
Old Oct 20, 2005 | 05:50 PM
ghost.rider's Avatar
ghost.rider
My yellow top died, wouldn't hold a charge, in less than 3 years.
No more Optima's for me.
I now have a fine $40 Kirkland battery from Costco
Old Oct 21, 2005 | 12:48 AM
  #33
GrayC5's Avatar
GrayC5
Neither. In model year 2004, GM went to a standard AC-Delco top-post sealed lead (liquid) acid battery and, as far as I know, this was the battery installed in all 2004 C5s. GM installed the AC-Delco AGM batteries beginning in model year 2001 through model year 2003. My understanding of GM's reason for going to the top-post sealed lead acid battery in 2004 was due to the number of premature failures people were experiencing with the AC-Delco AGM batteries.
Thus far, I haven't read or heard of anyone having great problems of any kind with the top post sealed lead acid battery GM used in 2004. The battery with which many people were experiencing leakage problems was the AC-Delco side-post sealed lead acid batteries that were installed in the C5 prior to model year 2001.
Hope this helps.
