Fred Beans October C5 Specials!
Thank you for your interest in our October specials. This month, we will again offer any single part 499.00 and under @ 10% over dealer cost and any single part 500.00 or more @ 5% over dealer cost. I must stress, if you are interested in anything other than what's listed here, please email me directly, gculley@fredbeans.com, and I will respond as soon as possible.
I would also like to take this opportunity to let you know of our future at our parts department. In the next 3 months we will be adding Nissan and Saturn franchises. Nissan will move in temporarily with us on October 17th until our new Nissan store, right next to ours, is finished in the middle of December. When Nissan moves out we will be welcoming in the Saturn franchise to our own parts department. The Saturn servicing shop has been added as an addition to our existing facility that is 5 years old. Currently the Saturn franchise is building it's own showroom out in front of our Pontiac lawn. I tell you this to let you know what is going on and to be patient with me. With all that is going on and the responsibility and the time going into all of this my time is a bit stretched.
Last but not least, another time stretcher. I have been in the midst of developing a website for all of our wonderful Fred Beans customers. It will be very user friendly and will provide the ability for you to obtain pricing and shipping quotes. You will also be able to look up items and add them to your cart.
I thank all of you for becoming our customers and friends and providing us with the ability to tremendously grow our department and business.
Enjoy your specials. I have spent a lot of time on this stuff!!
-Gene
||--Genuine GM C6 Z06 Shifter Kit--||
15232011 – C6 Z06 shifter
10354701 – C6 shift ****
11609670 - Bolt
Complete kit 180.82 + 18.50 shipping!
||--Genuine GM C6 Shifter Kit--||
15232012 – C6 shifter
11609670 - Bolt
Both parts 209.00 + 18.50 shipping
||--Genuine GM Engines--||
12498399 – 2002 + LS6 engine – 5130.13
12480030 – GM Performance Parts C5R block – 6350.00
89017654 – LS2 engine – 4899!400 below dealer cost!
12568950 – LS2 bare block – 951.83 + 90.00 shipping
12572808 – 6.0 cast iron bare block – 651.59 + 90.00 shipping
||--Genuine GM Z06 Items--||
Z06 calipers – 337.46 + 15.50 shipping
Z06 front screens – 100.82 + 9.95 shipping
Z06 front brake ducts – 10295976, 10295977 – 16.94 each + 9.95 shipping
Z06 rear screens (scoops) – 10322761, 10322762 – 58.15 each + 12.50 shipping
Z06 rear brake ducts – 10425977, 10425976 – 16.65 each + 8.60 shipping
Z06 2004 shocks – 335.48 + 23.50 shipping
Z06 sway bar kit – 236.10 + 28.95 shipping
Z06 sway bar kit (insulators and bars only, no end links) – 166.02 +26.50 shipping
Z06 front brake pads – 88952008 – 111.61
Z06 rear brake pads – 12530688 – 52.22 – shipping for front and rear is 14.50
Z06 rear differential assembly – 12572683 – 1010.19 + 90.00 shipping
Z06 front suspension spring – 22178729 – 416.34 + 28.50 shipping
Z06 rear suspension spring – 22188038 – 416.34 + 28.50 shipping
||--Genuine GM HUD Setup--||
10279814 – HUD – 183.34
12198648 – Switch – 69.25
10425223 – Bezel – 18.67
Total setup is 271.26 + 18.50 shipping!
||--Genuine GM Tire Pressure Sensors/TPM--||
2001-2004 Sensors
25773946 - sensor – 30.72 each
15125473 - nuts – 2.66 each
Total setup is 133.52 + 15.50 shipping
97-2000 Sensors
10438853 - sensor – 74.61 each
10268439 - nut – 1.36 each (5 pack)
10268438 - washer – 1.36 each (5 pack)
Total setup is 312.04 + 15.50 shipping
||--Genuine GM Corvette Clutch Parts--||
89059282 - LS6 Slave Cylinder – 101.83
12564455 - LS6 Master Cylinder – 103.86
12570806 - LS6 Clutch Kit – 369.99
14061685 – LS1/LS6 Pilot Bearing – 9.16
Shipping for clutch is 45.00. The clutch + any other components is 55.00 shipping
||--Genuine GM LS2 Items--||
89017648 – LS2 intake manifold – 248.13 + 9.95 shipping
12570790 – LS2 throttle body – 235.62
12572174 – LS2 fuel rails – 106.17
89017587 – LS2 injector o-rings – 20.09
||--Genuine GM LS6 Intake Manifold--
88894339 - Intake Manifold Only - 425.28!!
88894339 - Intake Manifold W/Coolant Pipes And Plugs - 466.86 shipped
||--Genuine GM UltraGuard UPF 44 Oil Filters--
25329389 - UPF 44 Oil Filter
Must order in cases of 6 @ 47.99 shipped!!
||--Genuine GM Cylinder Head Bolts And Gasket Kits--||
12498543 - 97-01 LS1 Engine Head Gaskets (2) – 33.48
12498544 - 02-04 LS1 & LS6 Engine Head Gaskets (2) – 23.86
12498545 - 97-12/03 LS1 & LS6 Engine Head Bolts – 16.21 per head
17800568 – 01/04 – present LS1/LS6/LS2 Head Bolts – 15.66 per head
If you’re not sure which bolt kit to use please email us your VIN# and we’ll tell you!
||--Genuine GM Ceramic Brake Pads--||
88909667 – Front ceramic pad kit
88909668 – Rear ceramic pad kit
Both front and rear ceramic pad kits 115.99 shipped!
||--Genuine GM Brake Rotors--||
OEM
10445856 – RF rotor
10445857 – LF rotor
10445858 – RR rotor
10445859 – LR rotor
Front and rear rotor sets 266.99 shipped!
AC Delco Performance Drilled/Slotted
88926731 – RF rotor
88926732 – LF rotor
88926733 – RR rotor
88926734 – LR rotor
Front and rear rotor sets 203.99 shipped!
||--Genuine GM T1 Engine/Suspension Items--||
T1 shocks – 583.48 + 28.50 shipping
T1 trans cooler – 877.68 + 28.50 shipping
T1 sway bar pkg with insulators and end links – 624.89 + 55.00 shipping
T1 complete suspension package – 2556.72 + 75.00 shipping
T1 suspension springs 696.17 each + 28.50 shipping each
||--Genuine GM Engine Parts--||
12564824 - '02 LS6 Cylinder Head (Assembly) – 729.75
12564825 - '02 LS6 Cylinder Head (Bare) – 535.66
12480110 - ASA Racing Cam - 375.87
12480033 - LS1 Hotcam Kit - 430.61
88958622 - LS6 CNC Ported Cylinder Head (Assembly) - 989.99each!!
||--Helms Service Manuals--||
'97'- '05 Corvette - 124.95 shipped!!
Please Call For Any Other Make/Model Vehicle!
||--Genuine GM LS1/LS6 Fuel Rail Covers--||
12559261 - '97-'98 LH Fuel Rail Cover (Black With Red "Corvette" Lettering)
12556455 - '97-'98 RH Fuel Rail Cover (Black With Red "Corvette" Lettering)
Both FRC’s 50.78 + 12.50 shipping
12561503 - '99-'02 LH Fuel Rail Cover (Black with Red "Corvette" Lettering)
12561502 - '99-'02 RH Fuel Rail Cover (Black with Red "Corvette" Lettering)
Both FRC’s 60.62 + 12.50 shipping
12564257 - '01-'02 LH Fuel Rail Cover (Red With Black "Corvette" Lettering)
12564258 - '01-'02 RH Fuel Rail Cover (Red With Black "Corvette" Lettering)
Both FRC’s 89.58 + 12.50 shipping
Fred Beans Pontiac Buick GMC Terms And Conditions Of All Sales:
We reserve the right to change the price of any part at any time and/or refuse to sell a part for any reason at any time. Price changes that can be made through the month are final and all sales before and after the price change are final. We will accept no returns after 30 days and all boxes or packages must be in the same condition as which they were received. If a package is received in anything other than perfect manner, please call and note upon receipt. Anything noted after the fact is the responsibility of the buyer. All returns are subject to a 20% restocking fee and/or a fee for unacceptable boxing or packaging. We reserve the right to change the terms and conditions of a sale at any time for any reason.
We seem to be making it through our construction and parts department revamping pretty well. We are slightly backed up but nothing more than a 24 hour backup.
I am working with GM on the Z06 brake setup and we hope to offer up to 300 brake packages in the 1700 dollar range to you forum members.
The LS7 engine is 12,595 and we were allocated only 1 and have sold it. I heard a bit more info today that possibly in the near future we will be able to order more.
We have a few pallet loads of 2006 Z06 shocks coming. Stay tuned.
We have LS7 clutches and flywheels in stock!!
The website is coming together well. You will be happy!
Please be patient with us during this busy/tough moment.
Thanks. Gene
-Gene
We do not, but there are some who are selling this on the forum.
-Gene
