Help with Warranty
The sales guy says this is similar to manufacturer's bumper-to-bumper. Though looking at the contract it is not an exclusionary warranty but it is inclusionary. Looking at it could you tell if anything important or major is missing (not covered). I've highlighted some conditions in Exclusions part. I know you guys have lot of experience, is there a part which can go bad at these many miles and not covered by this warranty.
Appreciate your time..
thanks.
farhan.
http://www.hamaridunya.com/upload/Warranty_Contract.gif
Bill
Bill
GMPP covers wear and tear??
Here's "MajorGuard," their "most comprehensive coverage," and what's not covered (sound like wear an tear items):
Unless required in connection with the repair of a covered part, WE will not pay anything under this Agreement for engine tune-up, suspension alignment, wheel balancing, filters, lubricants, engine coolant, drive belts, radiator hoses, heater and vacuum hoses, windshield wiper blades, air conditioning recharging, fluids, spark/glow plugs and wires, brake pads and linings, brake shoes and rotors, manual clutch disc, or any maintenance service or part required to be performed or replaced as recommended by the vehicle manufacturer's Maintenance Schedule.
Additionally, neither rust damage nor any of the following parts as defined by the GM Parts Manual or services are covered under any circumstance: sheet metal, chassis frame, cross member, body rails, body panels, carpet, weather-strips, lenses, sealed beams, light bulbs, tires, trim, convertible or vinyl tops, moldings, bright metal, upholstery, paint, exhaust system, catalytic converter, hinges, brake drums, shock absorbers, batteries, carburetor, correction of air and water leaks, wind noise, odors, squeaks, rattles, contaminated fuel systems, bumpers, body parts, and glass.
GMPP is the best, but at 60K miles, it isn't going to be cheap if you can get it. In the past you could not renew an extended GMPP warranty. Today you can as long as your current GMPP warranty has not ended. No warranty covers parts that wear, which include clutches, associated clutch parts, paint, molding, hoses, etc.
