Is there a big difference?
Old Oct 13, 2005 | 03:50 PM
devo's Avatar
devo
St. Jude Donor '03 & '05
Default Is there a big difference?
What is the difference between Z51 springs and ZO6 springs?
Old Oct 13, 2005 | 03:58 PM
simpleman68's Avatar
simpleman68
I believe the spring rates are fairly close to each other.
I wouldn't take a newer Z51 suspension and replace it with Z06 stuff. I think the difference would not be worth the money spent.
IF you have older suspension, then I think it would be money well spent to match the springs/sways. This is what I did and I really appreciate the improved handling.
Of course I went from base suspension on a newer car, so the difference was more dramatic.
I matched these up to the Bilstein Sports and the combo is very streetable. Firm ride with great handling and no side stepping of the wheels (still on Mich PS run craps) yet I don't get beat up on everyday roads.
Scott
Old Oct 13, 2005 | 04:13 PM
User 81424's Avatar
User 81424
FE4 Suspension
The Z06 features a suspension system all its own designated FE4. It's not available on other Corvette models but is standard equipment on the Z06. It features a larger front stabilizer bar, a stiffer rear leaf spring, revised camber settings and unique shock calibrations, all engineered with a bias toward maximum control during high-speed operation. The suspension component specifications are:
Front stabilizer bar diameter (hollow): 30mm with 4.5mm-thick walls.
Rear transverse composite spring leaf: 125 N/mm versus 113 N/mm of the Z51.
Camber, front and rear: Z06: -0.75° (coupe/convertible: -0.25°).
The Z06's negative camber helps to keep the tire flatter in relation to the road, and raises the tire contact patch for greater grip while cornering. When coupled with other special Z06 components, the combination provides unparalleled, all-out racetrack performance, which is what the Z06 is all about. During development testing, Corvette engineers were able to generate racetrack speeds that improved Z06 performance by an average of 3 to 4 seconds per lap over last year's hardtop model on typical 2-mile closed-circuit road courses. This we were able to test for ourselves at the Mid-Ohio Sports Car Course in Lexington, where we had the chance to drive a standard coupe and a Z06, back to back.
If you add Z06 or better anti-roll bars and do not increase the rear spring you may not the way she handles in a curve.
Old Oct 13, 2005 | 05:23 PM
devo's Avatar
devo
Originally Posted by MAJ Z06
FE4 Suspension
Thank you
So the main difference is in the rear spring the front springs are close.
Old Oct 13, 2005 | 05:36 PM
User 81424's Avatar
User 81424
Thank you
Front are the same.
Old Oct 13, 2005 | 07:21 PM
04BlueGoose's Avatar
04BlueGoose
Hey MAJ Z06
What have the guys done to the ride etc that have put 04 Z06 bars and shocks on the FE1 suspension cars?
Old Oct 13, 2005 | 11:23 PM
GeorgeB's Avatar
GeorgeB
You may find this interesting:
http://www.caranddriver.com/article....rticle_id=7004
To Is there a big difference?
