Help - I'm getting lean codes after LT install
Old Oct 13, 2005 | 11:12 PM
2GOFAST's Avatar
2GOFAST
Default Help - I'm getting lean codes after LT install
Installed FLP long tube headers with high flow cats. All 4 O2 sensors are connected. Also have a Haltech Stinger Intake.
Engine Light is now coming on and getting lean codes P0171 and P0174. Both are shown as history codes.
How can I fix this? Any ideas as to why I am getting these codes?
Your help is appreciated.
Old Oct 13, 2005 | 11:19 PM
terlox's Avatar
terlox
It could be your system is too efficient now. You may need to have your PCM reprogrammed to compensate for the increased flow.
Old Oct 14, 2005 | 12:58 AM
Mr. Big's Avatar
Mr. Big
St. Jude Donor '07-'08
you shouldn't get lean codes from a header install. I have heard a lot of people say they will lean out the car, but after 10-15 header installs on the f-body and y-body i have never had one throw a lean code just becasuse the efficency. First thing i would check is to make sure there are no exhaust leaks before the 1st set of sensors. If you have a leak, air gets the system causing it to think the car is lean.
Check for leaks before you spend the money on tuning
Old Oct 14, 2005 | 02:49 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Reset the PCM, if they return, you may need some programming changes.
Old Oct 14, 2005 | 08:43 AM
2GOFAST's Avatar
2GOFAST
I'll reset the PCM codes now. I'll check for exhaust leaks tonight.
Anymore suggestions?
Old Oct 14, 2005 | 09:07 AM
chaase's Avatar
chaase
St. Jude Donor '12
Also check your connections to the stinger and make sure they didn't loosen up. You may end up needing a tune. I was getting those same codes after the stinger install. It is not very common, but it does happen.
Chris
Old Oct 14, 2005 | 11:04 AM
c131frdave's Avatar
c131frdave
Well, I'm a total newbie to the Corvette (just got my first one last week! ) but I used to build hot rods in my youth. If you don't change the fuel schedule, of course you'll get a lean condition. That's kind of the point. You want to pump as much air as possible. With a more efficient exhaust and intake, you pump more air. So if the fuel is the same, you go lean. Obviously the Corvette's computer will try to compensate when in closed loop, but if it's anything like the LT1 computer, it can only go so far. Also, when you hammer it, the computer goes out of closed loop and meters fuel from a chart. I vote for the PCM tune.
Now, if you're getting the codes when just putting around town, well, obviously you have a leak. But if you get them when hammering the gas, then it's reprogram time. Also, I belive it takes a few minutes to go into closed loop (engine warm up), so you're going off the map sensor, tps, and a chart stored in the computer. Again, that could be too lean (but I doubt it). As a former hack with LT1 Edit, I can tell you there's lots of stuff in the GM fuel injection code that can make a car go lean.
Of course, I have zero LS1 experience, so I might be off my rocker.
Old Oct 14, 2005 | 11:14 AM
Jack Behrle's Avatar
Jack Behrle
I installed Kooks LT, an LS6 manifold and a mild cam recently. Left the rest of exhaust stock (Have an x-pipe). According to before and after mods A-Tap shows LTFT changed only a tiny bit (less than a half a point) so I doubt the headers themselves are causing the codes......(This assumes you were failrly close before the mods)
Just my .02 cent though
Old Oct 14, 2005 | 12:49 PM
2GOFAST's Avatar
2GOFAST
FYI - I have reset the codes and they have not reappeared - yet (only taken 3 shorts trips of less than 3 miles each). The codes and engine light have only happened when I drive the car for an extended distance/time (such as more than 5 miles). Also, I have been using WOT at times.
I appreciate all of the comments/thoughts and suggestions - keep them coming.
I will be putting on some after market mufflers soon - so i think if a tune is needed I should wait until the new mufflers are on the car. Is there a problem waiting for the tune (assuming the lean condition reoccurs)? I certainly don't want to cause damage.
thanks
Old Oct 14, 2005 | 03:39 PM
jawsski's Avatar
jawsski
Same thing for me ,cept no cam change
Hi Jack
Old Oct 14, 2005 | 07:09 PM
vetpet's Avatar
vetpet
I installed a complet new exhuaust sytem front to back consisting of LT headers, random tech hi-flo cats, X pipe and Z06 Ti mufflers. Not one code was set. Installed a head and cam package afterwards and still did not set any codes. This was all before getting any tuning done. I don't think your codes have anything to do with the headers themselves. You mentioned history codes which means that the problem occurred some time before you installed your headers. History codes indicate a problem has occurred but did not occur enough times or for a long enough time to set a DTC in your display. I'd say you've either got a leak around the header flange or right at the O2 sensor. What kind of gaskets did you use with the headers? Also, based on the age of your car, you might need to replace the O2 sensors. Hope this helps.
Old Oct 14, 2005 | 09:58 PM
2GOFAST's Avatar
2GOFAST
The car is a 2004 so I doubt the O2 sensors need replaced. I used new gaskets. I used the earlier C5 style with the round openings to match the headers.
The check engine light came on which, i assume, means that the problem happened at that time.
Any more advice or thoughts??
Old Oct 14, 2005 | 11:43 PM
Bob50th's Avatar
Bob50th
thanks
FWIW
I had similar codes when I had the long tubes installed. I believe it is the coating inside the headers causing this because the codes became less frequent and then disappeared over a few months.
Old Oct 16, 2005 | 11:15 AM
2GOFAST's Avatar
2GOFAST
Thanks for all the help.
I reattached my air intake and checked for leaks.
I have not received anymore codes
I'll see what happens today - I am going to a long drive - only a few days left before winter storage
Old Oct 16, 2005 | 02:14 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
I'd be inclined to look upstream since you had codes for both banks (rather than say leaks at both collectors.) For my money a leak behind the MAF is the best candidate.
To Help - I'm getting lean codes after LT install
