Help with gauge cluster...
Old Oct 18, 2005 | 12:02 AM
thefritz1's Avatar
thefritz1
Default Help with gauge cluster...
How do I remove the black trim around the gauge cluster (the piece that covers the DIC buttons (reset, gauges, etc.) I purchased the Ultimate Dash Kit and need to remove that piece.
Thanks.
Old Oct 18, 2005 | 09:11 AM
GUSTO14's Avatar
GUSTO14
Originally Posted by thefritz1
How do I remove the black trim around the gauge cluster (the piece that covers the DIC buttons (reset, gauges, etc.) ...
Thanks.
The first thing you have to do is remove the cluster from the vehicle. The trim is removed from the backside via a number of screws around the perimeter. Be very gentle when removing and reinstalling these screws, it is easy to twist of the plastic retainers... you'll see what I mean when you take it apart.
There is a Tech-Tip on how to remove the cluster above and it is much simpler than some of the older Corvettes. Follow it or get a factory service manual and you will find it not too difficult a job.
Good luck and go slow... GUSTO
Old Oct 18, 2005 | 10:33 AM
AnteVenom's Avatar
AnteVenom
Cruise-In IV Veteran
Daytona Jam 1 Veteran
Not sure if you have the cluster out already but in the event you do not there are a good set of instructions on the whole removal process at the link below
http://www.vetteessentials.com/instr...zel_howto.html
To Help with gauge cluster...
