LS7 Crate Engine Arrives!
Old Oct 18, 2005 | 07:01 PM
Gene@FredBeans's Avatar
Gene@FredBeans
Default LS7 Crate Engine Arrives!
Hi All,
We received one of the first LS7 engines today. We are one of the allocated dealers to receive one. GM made 139 of them and we were lucky enough to receive one. I had already taken a 5,000 deposit on it a couple of months ago.
Just wanted to let you guys know they are starting to trickle in. I've talked to my GM rep several times about getting another, and we'll see. If I get another I will let everyone know. Hopefully our customer tells a little of his story and gives us some pics and HP ratings.
Gene
Old Oct 18, 2005 | 07:17 PM
shulamite's Avatar
shulamite
So what should a person expect to pay for a LS7 crate motor? Does anyone know what it would take to install it in a 02-A4 vert.?
Old Oct 18, 2005 | 07:57 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Old Oct 18, 2005 | 08:02 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Gene,
What's the cost out the door and what's needed to shoehorn it into a C5 (wiring, PCM, mounts etc.)????
EG
Old Oct 18, 2005 | 08:30 PM
sprfreek's Avatar
sprfreek
Originally Posted by EnglandGreen
Gene,
EG
i've been looking into the exact same thing
Old Oct 18, 2005 | 11:54 PM
D C's Avatar
D C
USMC (retired)
Gene,
EG
Old Oct 19, 2005 | 02:01 AM
3 Z06ZR1's Avatar
3 Z06ZR1
Does it match the 402- 408 ls-2's.
Money wise,power wise
Old Oct 19, 2005 | 07:17 AM
David426's Avatar
David426
I assume that since this is one of the first crate motors, that Mr. Gene will be the first at doing this motor swap.
Old Oct 19, 2005 | 07:39 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Originally Posted by John Shiels
Old Oct 19, 2005 | 11:15 AM
ArKay99's Avatar
ArKay99
I read a while ago it would be around $17k-$18k. So you could multiply the increased hp figure power by 100 and add that to the cost of an LS2.
I believe it is rated at 105hp and 105tq more - at the crank.
I'm interested in one of these with a new Z06 wrapped around it. Then maybe some turbo's?
Old Oct 19, 2005 | 11:21 AM
5.0_CJ's Avatar
5.0_CJ
this is a much better motor than the LS2 -- its dry sump among other things.
Old Oct 19, 2005 | 12:22 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
It doesn't come with the dry sump. SDPC and GM are working on a PCM "workaround" (crank sensor). FWIW.
Old Oct 19, 2005 | 01:55 PM
Umrswimr's Avatar
Umrswimr
From: Overwhelmed as one would be, placed in my position.... DFW, TX
St. Jude Donor '05
The 402's are making about 450 rwhp with fairly mild cams for half the price. So basically they make about the same power with the price advantage heavily going to the LS2. Granted, the LS7 has a lot more potential....
Old Oct 19, 2005 | 03:46 PM
edensknight's Avatar
edensknight
Great heads up, Gene. Please do keep us informed about pricing and any typical conversion headaches. We are all interested in the C5 retro-fitting abilities of this amazing new engine.
Old Oct 19, 2005 | 06:53 PM
John Shiels
should be about 13+
Old Oct 19, 2005 | 08:29 PM
99blackFRC's Avatar
99blackFRC
I plan on putting everything on our website so you'll see the entire progress every step of the way
Old Oct 20, 2005 | 06:50 AM
Hokie's Avatar
Hokie
Can't wait until that beast gets here next week. Thanks again Gene!
To LS7 Crate Engine Arrives!
Old Oct 20, 2005 | 07:56 AM
Jstyle's Avatar
Jstyle
Old Oct 20, 2005 | 07:00 PM
Gene@FredBeans
No problem, keep us informed. Everyone is all ears. . .
Old Nov 2, 2005 | 02:42 PM
99blackFRC's Avatar
99blackFRC
Default Pics of the beast
Some pics of her after pulling the wrap off
http://filebox.vt.edu/users/mkoch/offtruck.jpg
http://filebox.vt.edu/users/mkoch/garage1.jpg
http://filebox.vt.edu/users/mkoch/427.jpg
http://filebox.vt.edu/users/mkoch/LS7.jpg
http://filebox.vt.edu/users/mkoch/ls72.jpg
http://filebox.vt.edu/users/mkoch/ls73.jpg
http://filebox.vt.edu/users/mkoch/ls74.jpg
