Would you use Castrol Syntec?
I'm currently on my final fill of Amsoil series 2000 0W30. Once I'm done with this round of oil, I'll be going back to Mobil1. Why? Because it is cost effective and conveniant to buy locally.
Nothing wrong with any of the products that meet the spec listed above, and I'm with Rockin'Silver 02... You make a claim, you might want to show facts...
Look guys, this discusssion gets old and comes around about every 6months. A good quality synthetic oil from the majorety of manufacturers out there is gonna be fine in most of your cars. Is brand X better than brand Y? Maybe in that specific vehicle's case, but not necessarily in "ALL" cases... Go over to www.bobistheoilguy.com and get an education on oils and lubricants. I've got a number of tests from Amsoils independant lab for testing, and we beat the snot out of both amsoiil and Mobil1 in my truck (towing scenarios) and my vette, which was used during track days, and with various synthetics, we were getting a LOT of mileage out of both. Like 12K miles out of the chevy Silverado with more life left in the oil at the change interval...Saw that on BOTH amsoil and Mobil1 and I bet I'd have seen it on Syntech as well...
Just use good synthetic oil that meets the required spec, per vehicle manufacture recommendation.
It's oil, not the cure for cancer...
Mike
and has been used on new cars from SLP SSCamaro cars. with G.M.
approval. Show some proof.
Read GM's own bulletins it was stated again last march in GM's Techlink and also in reference guide via SI that the policy was changed to do away with oil makers making the claim when GM never approved them so the oil must also be registered by GM
Fact is GM has released multi times about oils must now be registered to rid the whole marketing claim of oil makers saying they meet GM specs when GM never approved and registered them as doing so.
People will use whatever the oil they want but they also should know what new rules GM has put on the oils we use
Mike
Rsty
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Yes GM states oil must meet 4718M, it also says the oil must have been tested and have the starburst label and GM can anytime change their own standard which since last year changed to include the vendor must be registered which means it complies with GM and API requirements and means it has to pass their tests and not some vendor simply claiming to meet GM standards when in fact GM never tested them.
I always have wondered why these non GM approved oil makers never spend some of their profits for API certified or GM tests and get it over rather then making a claim about exceeding GM standards well now they have to prove they are GM approved.
If all it took was to register with GM there would be many more then just 3 vendors approved for synthetic grades would'nt there being this change to 4718M happened last year and if we like it or not that is what GM has changed to clear up who really meets the standards GM tests to.
Why should some oil makers spend the time and money to have their products GM approved while other makers do nothing yet simply claim they meet or exceed a GM standard they never allowed GM to test so being we could use **** instead of oil if changing often enough but my point is when someone asks if they should change brands GM requires they should know what vendors in fact comply with their GM warranty.
That is nonsense, just another way for GM to make a buck. Castol Syntec is just as good as Mobil 1 regardless if GM "approves" it or not. That's just a money thing, nothing to do with oil quality.
Mike
Your list doesn't have Mr Goodwrench G.M's Own oil? Got to be bogus. I like Syntec But A lot of Good car owners. Might have great luck with others.
I also sold my vette a month ago so if anyone is looking to try this oil I have 13 quarts for sale.
You can do a Google search and find out a lot about it.
One thing to keep in mind here is that not all synthetic oils are created equally. Most synthetics on the market (including Castrol Syntec) are a Group III synthetic, which uses a highly refined petroleum base stock. A group III synthetic is much less costly to manufacture than a Group IV or V synthetic. API has declined to define synthetic. Calling a group III oil "synthetic" was upheld in the courts (Mobil sued Castrol).
AMSOIL Series 2000 0w30, AMSOIL SAE Synthetic 5w30 and Mobil 1 are Group IV, PAO based, synthetics and both probably have a small amount of ester additives to the basestock along with other anti-wear and detergent additives. Redline is a Group V, ester based, synthetic.
