PIC---ls1/6 pulley holding tool
Old Oct 18, 2005 | 10:51 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Default PIC---ls1/6 pulley holding tool
HERE'S THE LINK, http://ls1tech.com/forums/showthread.php?t=331315
Old Oct 19, 2005 | 01:22 PM
The Wrench's Avatar
The Wrench
Here's an interesting theory:
The pulley is not pinned to the crank, so when you lock down the pulley and start turning the bolt, is it possible for the bolt to spin the crank inside the pulley rather than actually loosening/tightening the bolt in the crank?
If you had locktite on the bolt threads, it might happen.
Probably not likely, but food for thought since spinning a pulley on the crank even a fraction could lead to it wanting to spin more easily later.
Hmmm, I must be bored today.
DG
