Problem solved (burnt lines).. Electrical help needed..
Old Oct 21, 2005 | 12:35 AM
24hr Z06's Avatar
24hr Z06
Default Problem solved (burnt lines).. Electrical help needed..
I think I found the root of all my problems.. After replacing the 02 sensors, MAF, and while replacing the spark plugs I decided to look at all the wires near the headers and found whats below..
This bundle which got destroyed is located on the passengerside, right near the starter.. It is a 5wire bundle with 1-green, 1-blue with white strip, 1 ground, 1-black, and 1-yellow..
Can someone PLEASE find out what these wires are for? I have a 2004 Z06..
Now, any ideas on how to repair this? I was thinking about removing the passenger side header, probably the starter, and then cutting out the destroyed sections and soldering new sections from below as I doubt I can do it from up top.. Ideas?
Remaining Pictures
Large Version
