Tunnel Plate
Old Oct 22, 2005 | 07:35 AM
MYRagtop's Avatar
MYRagtop
Default Tunnel Plate
Can the factory tunnel plate be removed without taking the stock exhaust off of the car. Can the reinforced plate (abs of Steel) be installed in the same manner or do you have to remove the exhaust.
Old Oct 22, 2005 | 07:40 AM
MTurnbo's Avatar
MTurnbo
I had one put on my vert and I don't see how you could do the job without dropping the exhaust. It's so tight under there and there are 32 bolts to remove and put back in.
Old Oct 22, 2005 | 07:48 AM
WKMCD's Avatar
WKMCD
Negative.
Old Oct 22, 2005 | 08:13 AM
Roadrace65's Avatar
Roadrace65
The exhaust has to come off – I installed the thick aluminum C6 plate, it fits on the C5 and its Cheap!
Old Oct 22, 2005 | 09:33 AM
striper's Avatar
striper
How thick is it and does it bolt up with no mods? Also, how does it compare price-wise with the Elite plate?
Old Oct 24, 2005 | 01:56 AM
Last C5's Avatar
Last C5
Old Oct 24, 2005 | 01:40 PM
Roadrace65's Avatar
Roadrace65
No Mods - it bolted right up. It's about .200" 3/16' thick. I think I paid about $50-60 from my Chevy parts guy.
Old Oct 24, 2005 | 01:53 PM
kg54trains's Avatar
kg54trains
Where did you buy and what brand or Mfg was the part from.
Old Oct 24, 2005 | 02:12 PM
Nulltime's Avatar
Nulltime
Ok time for the noob question. Why add the weight of an added plate to the car?
Old Oct 24, 2005 | 02:26 PM
Roadrace65's Avatar
Roadrace65
It's a stock C6 part - from GM
Old Oct 24, 2005 | 02:48 PM
Lovin It!!! - C5's Avatar
Lovin It!!! - C5
Stiffens the body / frame of the vehicle to improve traction / handling.
Old Oct 24, 2005 | 03:21 PM
Nulltime's Avatar
Nulltime
Ah ok that makes sense, thanks!
Old Oct 24, 2005 | 11:11 PM
striper's Avatar
striper
Along with stiffening the structure of the car, which will lessen any creaking you may have and improve the handling, it will also reduce heat and noise through the console into the interior.
Old Oct 24, 2005 | 11:29 PM
04BlueGoose's Avatar
04BlueGoose
This would be a savings if the info pans out. I just e-mailed Gene @ Fred Beans to give me a price and part #. I will post info here as soon as he responds.
Old Oct 25, 2005 | 12:15 AM
JETZ's Avatar
JETZ
Has to be removed Mark!
Old Oct 25, 2005 | 04:10 PM
04BlueGoose
Gene from Fred Beans got back with a price of $48.00 but no part# also said n/a right now.
Roadrace65 do you have the part #?????
Old Oct 25, 2005 | 04:40 PM
Roadrace65's Avatar
Roadrace65
The Part Number for the C6 Tunnel Panel Reinforcement is 10384612, as per my trusted GM parts guy you have to put one on order and ……….wait……….
To Tunnel Plate
Old Oct 25, 2005 | 09:23 PM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
Keep in mind the stock C6 plate is only 1/8" thick aluminum and is not ceramic coated. Without the coating, it may actually increase console temperatures by retaining more heat from the exhaust.
Old Oct 26, 2005 | 12:54 PM
molson's Avatar
molson
Hey Mark,
I got mine from E.E.........ceramic coating is a must when you have headers.
Shipped it U.S.P.S. and there were no taxes!!
Mark
Old Oct 26, 2005 | 01:13 PM
04BlueGoose
Hey Roadrace65 Have you noticed this extra heating up issue? Have not heard of this problem with the C-6 guys i've talked to.
