Oil Pressure Sensor
Old Oct 22, 2005 | 11:35 AM
W Muller's Avatar
W Muller
Default Oil Pressure Sensor
I'm replacing my oil pressure sensor With a different brand. Has anyone had a failure on a Standard Motor products PS308?
Old Oct 22, 2005 | 11:36 AM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
I'm curious as well. I have heard of the Standard one. Mine just went bad again. This is the 2nd GM one that I have installed..
steve
Old Nov 1, 2005 | 11:21 AM
romeokc10's Avatar
romeokc10
Default 0il press. sensor
Who carries that brand?
Old Nov 1, 2005 | 11:32 AM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Where do you get these? Mine is running @ 130psi.
SNAKEKILLER!'s Avatar
SNAKEKILLER!
Are you doing it yourself?? or having a shop do it???
Old Nov 1, 2005 | 12:29 PM
thevelvetglove's Avatar
thevelvetglove
I changed mine out using the great pictures found on this site and I am not mechanically inclined. Used an original GM part. Don't over tighten!
Old Nov 1, 2005 | 08:12 PM
LoneStarFRC's Avatar
LoneStarFRC
I've had the PS-308 in mine for well over a year. No problems.
Check www.RockAuto.com that's where I got mine. HTH
Old Nov 1, 2005 | 08:15 PM
muncie21's Avatar
muncie21
All of mine were from GM, but I did notice that one had a copper base and the others were silver. I believe the one that was in the when I got it (dead) had the copper base, but I'm not 100% sure.
Old Nov 1, 2005 | 08:19 PM
JeepTJ's Avatar
JeepTJ
I plan on doing mine myself. Or Stangkiller (Chris) siad to "bring her over". "He could do in 2 hours."
I'm just try to figure out what else I can mod when doing this job.
Any ideas? I don't think a LS6 intake is worth the bucks.
Old Nov 1, 2005 | 08:35 PM
LoneStarFRC
A couple of things come to mind. Since the manifold has to come off (or at least come forward enough to get to the EOP sender), you might want to consider replacing the A.I.R. check valve that's next to the firewall. Sort of a preventative maintenance thing. No way to get to it without manifold removal. The other one, on the driver's side, is easy to get to any time you want.
The other thing is maybe to extend the length of the small 1/8" nylon vacuum line that plugs into the back of the manifold. Maybe add 3" or 4". You can get the rubber fittings as well as some extra line at the auto parts store. It will make it much easier to re-install the manifold without worrying about the line coming off.
Old Nov 2, 2005 | 10:50 AM
BMG50's Avatar
BMG50
Extending the small vacuum line was the best i could have done...after 2 gm oil senders went bad (1 in 1 day) i replaced it with a Standard PS-308 and ls-6 intake...been working now for about a month...trying to get the small line re-connected was the worse part of the job....
Old Nov 2, 2005 | 11:00 AM
Jay-rod's Avatar
Jay-rod
Maybe change out the Knock sensors while you are at it.JER
To Oil Pressure Sensor
