Park/Tail Lamps (Possible Switch Problem)
Sure would appreicate someone that has had this problem or who can diagnoise it to get back to me. I don't know what to check next; even though I suspect the switch itself might be bad. If in fact it is can it be replaced without removing the steering wheel?
Thanks in advance for any ideas or help that you might be able to give me.
Bill
I have been having problems with my park/tail/dash lgts not coming on all the time with the switch;they do work on the twilight mode. The head lamps always come on even thought the dash/tail/park lgts don't. And then there were times when they worked as designed. Sometime they would work 20 out of 20 times; other times I would have to turn them on and off 5 or 6 times and then they would come on. Now they won't come on at all other than setting the twilight mode on the DIC. So I thought maybe I had blown a fuse, checked that out today and it looked alright.
I don't know what to check next; even though I suspect the switch itself might be bad. If in fact it is can it be replaced without removing the steering wheel?Thanks in advance for any ideas or help that you might be able to give me.
Bill
Bill
GO
The switch is the most likely culprit in this mystery IMHO.
