Really Bad Night...
So I pull into some big parking lot and pop the hood... all i see is oil on everything (not a hole lot but splatters everywere)... Then i see that the hose that goes to the water pump (big one right by the tb) is almost off the water pump
.. It looks like it moved a good 2 inches outta its grove and oil was all over the hose.. I used some plyers to fix to the hose and put it back were it goes.. and check the oil (see if im low) and it was good. then poped the anti-frezze overflow to see if oil was in it (praying i did not blow a gasket) and it was all anti-frezze...
Now I checked and the car is not leaking anything. But it seems like my exhuast is smoking more then it used to, but it was 40 outside so i dunno. I was about 20 miles from home and the oil pressure was good so i drove home. Now the car is sitting and i dont know if something is broke or not..
Then when I walk in the door my mom tells me my dad is in the hospital cause he fainted while out at the bar with my mom and friends.. and also my buddy that was with me when the car was messing up got robbed at gunpoint in mt. clemens today.. Today is not a good day.
So does anyone know why the car would of make that hose almost fall off?? and why it would leak oil from it?? I need some advise..
sorry if grammer/spelling sucks im not in a good mood and its 3:35am
Good luck with the car and hope your Dad is ok
Hope this helps goodluck with your car.
-AkE
EDIT: I had a friend who blew his head gasket but the car would not leak anything until it heated up quite a bit. Would run fine, until it overheated, didn't leak any oil that I can remember but he was going through alot of water it would leak, burn, whatever.
Glad your Dad is OK.
Street racing is dangerous and illegal. Kill stories are not permitted at Corvetteforum.com. Take it to the track.
