Brake Light Help
Old Oct 24, 2005 | 11:13 AM
srchief100's Avatar
srchief100
Default Brake Light Help
The left brake lights on my coupe do not work. There is power to the bulbs, which I changed (twice just in case I had faulty bulbs). The tail lights, turn signal, works just fine. Only the brake light on the left side as the right is just fine. I'm stumped and hope someone here can help out. Thanks in advance.
Old Nov 17, 2005 | 01:13 PM
2KVetteMan's Avatar
2KVetteMan
I have the same problem, but it is my right. Changed bulb out and still no good.
Old Nov 17, 2005 | 01:30 PM
diviniti's Avatar
diviniti
St. Jude Donor '05
If there is power to the socket then I would think something is wrong with the bulb socket.
Old Nov 17, 2005 | 06:50 PM
VA 98 VETTE's Avatar
VA 98 VETTE
Take the breaklight assy out and move the bulb around in the socket while someone presses the brake pedal.
Old Nov 17, 2005 | 09:30 PM
dpd's Avatar
dpd
are you sure you have power to the brake lights?just because you have tail/turn signals,doesn't mean you have power for brake lamps.more than likely you have a bad turn signal switch or a bad ground.
Old Nov 18, 2005 | 11:51 AM
2KVetteMan's Avatar
2KVetteMan
DPD in my case I do have brake lights, except on the passenger side. I press the brakes and the driver side and middle brake light go on. I just put in new bulbs and still no luck.
I am going to pull the light out and jiggle the wires and see what is wrong.
Old Nov 18, 2005 | 12:44 PM
dpd's Avatar
dpd
i'm willing to bet you have a bad turn signal switch.when you press the brake pedal,power flows from the swith and through the t/signal switch out to he brake lights.move the steering column up and down[tilt]and see if you get them back,if so,you need a turn signal switch.
Old Nov 18, 2005 | 12:50 PM
2KVetteMan's Avatar
2KVetteMan
I will try that, thanks. by the way where is the turn signal switch? Have you replaced your before?
Thanks again.
Old Nov 18, 2005 | 01:07 PM
dpd's Avatar
dpd
i haven't replaced one in my car,but have on a s@#t load of gm cars since hitler was a kid[i've been turning a wrench a long time].it is a common problem on any gm car with a tilt column[that is moved quite a bit],the switch is in the column under the clock spring.it is not that bad,but if you've never done it before,it is easy to screw up.
To Brake Light Help
