Wheel Weights
Old Oct 24, 2005 | 11:21 PM
mrosa65's Avatar
mrosa65
Default Wheel Weights
I just bought a new set of chrome rims and I'm taking them to Goodyear tomorrow to have a set of GS-D3's put on themfor my 02 coupe. When I made the appointment by phone this afternoon the manager asked if I wanted to traditional wheel weights or the stick on type.
I've never had the stick on type on any previous cars and wanted to get some feedback on how well they hold up.
Thanks in advance,
Mike
Old Oct 24, 2005 | 11:22 PM
mrosa65's Avatar
mrosa65
I see I posted this in the FS section on not the general topics section.
Old Oct 24, 2005 | 11:40 PM
JON CONA's Avatar
JON CONA
Stick Ons Have Worked Fine For Me And They May Be Your Only Option If Your Front Rim Width Is 91/2.the Standard Clip On Weight Will Hit On The Edge Of The Upper Arm In A Sharp Turn. Hope This Info Helps....regards.....jc
Old Oct 24, 2005 | 11:49 PM
USAF_C17's Avatar
USAF_C17
DO NOT put regular weights on your chrome. They hit them on w/ a small hammer and it will prolly chip your chrome. Stick on weights work just as well. GL
Old Oct 25, 2005 | 06:02 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Most chromes I've seen including the ones I had at one time had standard weights on the inside lip and tape weights as close as possible ( make sure they clear the calipers ) to the outside of the barrel.........
Make sure you spring a little extra for a road force balance...
Old Oct 25, 2005 | 08:52 AM
hrcantrell's Avatar
hrcantrell
Default Road force balance
What is road force balancing? I have seen the term here on the forum but I have never seen it before I joined the forum. Thanks in advance for educating me. Harold
Old Oct 25, 2005 | 08:57 AM
mrm1149's Avatar
mrm1149
Many of the goodyear stores have it. It is a Hunter system which is primo for balancing tires and wheels. Best thing to do is ask if they have it AND a tech who knows how to use it.
Old Oct 25, 2005 | 09:13 AM
hrcantrell's Avatar
hrcantrell
Default Thanks
Thanks agin. Harold
Old Oct 25, 2005 | 02:55 PM
Ttop34's Avatar
Ttop34
It's also refered to as Load Force Balancing.
Old Oct 25, 2005 | 06:07 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
I think he means Road Force.
Old Oct 25, 2005 | 07:15 PM
C32B's Avatar
C32B
He probably did mean "load" force which is probably dialed up to be more realistic to a vehicle traveling "under load" such as a truck or passenger vehicle . . . for performance tires it may account for higher speeds . . . thats my .02 (or could be ) . . . in any event sounds like the thing to do so you get home safely and out for more cruizes!!
Old Oct 25, 2005 | 07:25 PM
mrm1149's Avatar
mrm1149
I guess we're all correct. Hunter's phrase is coined Road force which the way I understand it put a Road Load of sorts on the tires. Also matches the tire to position on the wheel if necessary. A MUST for aftermarket wheels especially.............
Old Oct 25, 2005 | 07:31 PM
mrosa65's Avatar
mrosa65
Well I just got back from the shop a little while ago. When I went in I asked for the road force balance and right away they started telling me how it's not any good and the usual blah blah blah...I asked them if they had the machine to even perform it and of course they said NO. So that would explain why they talked it down so much.
It was actually pretty sad dealing with this Goodyear dealership. I had a 2 pm "appointment" and I use that term very loosely, they didn't even begin to work on my car until after 5. Needless to say I was less then pleased, especially since I could have waited until 5 and had my GF give me a ride back to my house instead of walking the 3 miles. (I'll be 40 on Friday so I guess the exercise will do me good..lol)
I did at least get them to match the tire rack prices and cut me a 50% discount on the alignment so it wasn't all bad.
On the plus side, it was like driving a totally different car. Good bye runcraps. And the new rims look pretty darn good to boot.
Thanks for all the information and help you gave me.
Mike
To Wheel Weights
