How much difference will bigger gears make?
Old Oct 25, 2005 | 04:03 AM
motorpsycho98vette's Avatar
motorpsycho98vette
Default How much difference will bigger gears make?
I was wondering how much difference in hp or quarter mile times would it make if I changed my stock gears to a 3.73, I have a 98 6sp coupe? Any daily driving difference and how much will it cost with parts and labor? Any feed back is welcomed.
Thanks in Advance.
Old Oct 25, 2005 | 04:28 AM
Blow Torch's Avatar
Blow Torch
MP98
Although gears and TC (on an auto) are proably the best mods you can make in my opinion, if you have a 6 sp., you should already have 3.42s, and changing from those to 3.73s proably won't make a real big difference.
Old Oct 25, 2005 | 06:36 AM
PHPD7102's Avatar
PHPD7102
St. Jude Donor '14-'15-'16
Dont go 3.73 if you have a 6spd go with t e 4.10's. No discernable diff in gas milage and makes the car accelerate like a whole new animal, 6th gear is actually useable.!!
Old Oct 25, 2005 | 08:30 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
3.73s would cost effective unless you plan to be over 600 rwhp.
400 - 500 rwhp 4.10s
500 - 600 rwhp 3.90s or 3.73s
when I switched from 3.42s to 4.10s my 1/4 mile time dropped about .3 tenths (I went from low 13s to high 12s). I did have a run of 12.66 with the 4.10s, air intake, and cat-back. Most stock vettes are in the 13.3 range....
Old Oct 25, 2005 | 08:35 AM
Rays Vet's Avatar
Rays Vet
Old Oct 25, 2005 | 12:05 PM
motorpsycho98vette
How much are gears and installation? Do I have to change the whole gear box?
Thanks Guys,
Old Oct 25, 2005 | 12:34 PM
unstressed's Avatar
unstressed
The easiest way is to change the complete differential rather than swapping the internal gears. Most wil agree that DTE is the gear vendor of choice, and they get ~$1200 for the 4.10 in stage 1 config. If you already have 3.42's, they can be sold on the forum for ~$500. I suggest buying someones older core cheap (~$1-150) and using that for the core charge @ DTE.
You can find gear change write-ups if you search. There is good stuff on LS1tech.com too. Figure on $500-1000 for labor if you have someone else do it.
I am installing 4.10's in my car in 2 weeks, along with a LS7 clutch assy. It doesn't look that hard, just time consuming.
To How much difference will bigger gears make?
