I have a 99 Vert and the front tires are wearing badly on the inside tread of both. Is this an alignment problem ??? Toe in / caster adjustment ?? I have the tires balance and front end alignment every 5,000 mi. I did change out the stock swaybars front / rear with new ZO6 bars , end links and Bilstien shocks at 26k miles.. Car has 44K on it now. Thanks for the help
Its either a toe or camber problem, but if you align your car that often there is no excuse. Have you lowered it since the last alignment,that will cause neg. camber and wear the inside of the tires.
There is a lot of threads on this. The specifications are such that the front tires will wear on the inside IF you do a lot of highway (straight) driving. If you do a lot of curves they will were evenly.
I do a lot of highway driving (daily driver) and mine wear on the insides, I still get 55,000 miles from them (I drive pretty easy).
Someone posted alternate alignment specifications, but I can't find them.
sounds like too much negative camber. i had this problem with a different car and found out the springs could not maintain the stock ride height. with only 44k it might just be alignment prob. try a different shop.
Car is my daily driver and I do a lot of highway miles..I think your dead on its time to change alignment Shops. Thanks for the help
Stock C5 alignment will wear the tires on the inside, especially if you have runflats. Change the camber to 0 degrees and you won't have the problem on new tires. Your old tires that have bad wear will continue to get worse, but at a much slower rate.
The negative camber that causes the tires to wear on the inside is there to help the front tires stick better in turns. If you decide to run 0 degrees camber, depending on how you drive, the handling will deteriorate slightly. The stock spec is to have slight negative.
Yes, this is true. My '01 Z06 had the same problem, at 30K miles with lots of highway driving the front tires still had plenty of tread, but the inside edges were down to the cords. When I got new tires, I had the alignment done, and the shop told me that the stock setting was for negative camber, but he adjusted it closer to zero since I drive mostly long highway miles.
I haven't noticed much difference in cornering if any, but I did notice that it was a lot easier to point it straight down the road. Now, with 46k miles (16k on the new tires) the wear is even. Then again, I don't run autocross every weekend either, although I intend to try it a couple times next year.
KennyZO6,
Thanks for the info. I think I'll go with the adjustment closer to zero for the highway driving. I do not autocross either and have a heck of a time keeping car pointed straight. I was under the impression that keeping it straight had more to do with the charastics of EMT Tires (runflats). Since I need some new tires on the front I have been leaning towards non run flats all around. Thanks again.
KennyZO6,
Being a Z06, mine are not EMT, they're the Goodyear Eagle F1 Supercar (SC) that come on a Z06. They handle excellently on dry pavement, although I'm not thrilled with the way they work in the wet. My friend switched to the non-EMT Michelin Pilots on his Z06, which he far prefers for everyday driving, and they work much better if it's wet. He still switches back to the F1 SC's when he autocrosses.
My other friend has a Convertible, and he went through the same problem with inside wear. He switched to the Pilots also, which are EMT, and he says they're awesome. Good luck!
