Leaking tranny..
Old Oct 28, 2005 | 10:07 AM
SNAKEKILLER!'s Avatar
SNAKEKILLER!
Default Leaking tranny..
I have a leaking tranny on my 98 C5...Any ideas were it may be coming from...The pan gasket was determined to be ok...I have another on the way, but meanwhile have to stick to this one until the other one is upgraded..
Old Oct 28, 2005 | 10:23 AM
kromberg's Avatar
kromberg
Check the fill and drain plugs for tightness
Keith
Old Oct 28, 2005 | 10:49 AM
SNAKEKILLER!
Keith
Will do...
Old Oct 28, 2005 | 02:18 PM
Quacker's Avatar
Quacker
Not sure but I think there is a seal from the output shaft on the trans to the rear end. If the leak is driping where the trans bolts to the rear end thats it.
Old Oct 28, 2005 | 02:34 PM
JoshVette's Avatar
JoshVette
If it were me, I'd raise it up, check everythoing you can one time and clean it up real good and come back a day or two later and see if you can isolate the leak........I dont' know, but it's worth a try, could be more minor then needing a new trani., you never know
Old Oct 28, 2005 | 02:44 PM
Lovin It!!! - C5's Avatar
Lovin It!!! - C5
Been there before. Ouch
Old Oct 28, 2005 | 03:43 PM
SNAKEKILLER!
Sounds like the culprit..... Got a new tranny on the way....
Old Oct 28, 2005 | 03:46 PM
edensknight's Avatar
edensknight
Good advice.
Old Oct 28, 2005 | 07:32 PM
Lovin It!!! - C5
If its the output shaft seal, those are usually pretty simple to replace and not to expensive. Anybody know how much $ and trouble to replace one?
Old Oct 29, 2005 | 01:47 AM
PDQC5's Avatar
PDQC5
Try this website.
mikemercury.home.att.net/342.htm
Old Oct 29, 2005 | 01:57 AM
PDQC5's Avatar
PDQC5
Also try this website very detailed instructions.
http//fear.net/~dope/c5_rear_install.doc
Old Oct 29, 2005 | 09:14 AM
VetteTech81's Avatar
VetteTech81
GM came out with a redesigned out put shaft seal due to this problem. Enjoy the new trans..
-=Rick
To Leaking tranny..
