need help
Old Oct 29, 2005 | 11:41 AM
speedyjoe's Avatar
speedyjoe
Default need help
Just Installed Zo6 Heads And Cam And Intake On A 99 Frc Do I Need To Have The Car Tune And What About The Extra 600 Rpm That I Am Not Use Because The Zo6 Redline At 6500 And The Ls1 Redlines At 6000 How Much Et Am I Losing By Not Turning The Extra Rpm And Also I Went Out Last Night And The Crank Pulley Came Off If There Is A Knock With The Engine Will The Timing Be Retarded, Meaning If The Is Any Noise Heard With The Motor With The Knock Sensor Send A Signal To The Pcm To Retard The Timing
Old Oct 29, 2005 | 01:14 PM
EHS's Avatar
EHS
Wow --this sounds more like a 1:41 a.m. post than a 11:41 a.m.
Old Oct 29, 2005 | 11:10 PM
speedyjoe's Avatar
speedyjoe
Ttt
Old Oct 30, 2005 | 10:33 AM
speedyjoe's Avatar
speedyjoe
Ttt
Old Nov 4, 2005 | 05:57 PM
99vettecoupe's Avatar
99vettecoupe
Hey Joe. I would take it to someone that does LS1 edit or a tune like that. I think you'll be surprised at how much power is lurking in that motor with your upgrades. You can also have the rev limiter increased with LS1 edit. Anywhere between 6500 and 6700 is generally fine for a healthy LS1.
I'm not really sure I understand your question about the crank pulley.
Good luck.
Old Nov 4, 2005 | 05:59 PM
Z28TOZO6's Avatar
Z28TOZO6
Ttt
OK I give up what the hell does TTT mean?
Old Nov 4, 2005 | 06:00 PM
99vettecoupe
To The Top
Old Nov 9, 2005 | 03:10 AM
EHS's Avatar
EHS
Originally Posted by 99vettecoupe
To The Top
OK I give up what the hell does "To The Top" mean?
Old Nov 9, 2005 | 03:38 AM
jhong321's Avatar
jhong321
Did you use a new bolt for the crank pullie?? you are suppose to use the old bolt to put the crank pullie back and tighten it down then take out the old bolt and put the new bolt in and torque it down( remember these are strech bolts and can only be used once). if you don't do this the old bolt will back out and you can really mess up your motor. Trust me on this. i had to buy a new motor for mine when this happened to me because the previous owner did not do it right. plus go get a tune you will need it
Old Nov 9, 2005 | 07:20 AM
C5XTASY's Avatar
C5XTASY
TTT
Old Nov 9, 2005 | 08:52 AM
99vettecoupe
The last post within a forum will send that thread to the top. If you just want to send your thread to the top of the list but don't really have anything more to add, throw in a post of TTT.
Old Nov 9, 2005 | 11:45 AM
EHS's Avatar
EHS
Why would you want to do that -- if you have nothing to add, shouldn't you just let the thread die?
Old Nov 9, 2005 | 11:56 AM
Tigershark3's Avatar
Tigershark3
If you are the originator of the thread and have not gotten many replies this is a way of getting more reads/replies.
Old Nov 9, 2005 | 12:01 PM
EHS's Avatar
EHS
But maybe it wasn't that interesting to begin with, which is why it probably died.
Why torture and nag people -- this thread has gotten 119 views, and a total of 12 answers (about 10%), but only two that were relevant to the question (less than 2%).
Shouldn't it die out of a lack of interest at that point?
Falcon05Dad's Avatar
Falcon05Dad
And if someone other than the originator does the TTT, most likely they have a similar issue and are hoping for a reply.
Old Nov 9, 2005 | 12:05 PM
Falcon05Dad
Hmm, never thought of the Forum as a place for torture and nagging....
To need help
