H/C- Problem?
Old Oct 29, 2005 | 04:00 PM
Ken G's Avatar
Ken G
Default H/C- Problem?
I just had my new setup dyno tuned and we were a bit disappointed with the results. I was hoping to make 420-440rwhp with this setup but ended up with 414rwhp/398rwtq. Does anyone think that there is a problem or were my expectations just too high? My car is an '04 Z06 (stock dyno 356rwhp/349rwtq) with:
AFR 205's 66cc unmilled (possible F/I in future)
Dual coil valve springs
Hardened Pushrods 7.4"
ARP Head Studs
Stock rockers
Stock lifters
Cometic 0.04" head gaskets
Comp Cams 224/228 .581/.588 114LSA
Rollmaster Double Roller timing chain
Ported LS6 oil pump
Dynatech Supermaxx LT's with cats
Stock LS6 intake manifold/TB
Blackwing air filter
The car runs great and feels strong but only put out 414rwhp/398rwtq on the dyno. The dyno curves looked very smooth and the car kept making power up to the 6800 RPM limiter (sorry, I don't have a hard copy). The A/F was tuned to about 12.6-12.8:1 and about 28 degs. of timing adv. with no KR (higher timing got us no extra power).
I did the installation myself but there were no glitches. I did not degree the camshaft but I am 100% certain that it was good "dot to dot" alignment and the the timing chain crank sprocket was installed for standard timing. I also did not check pushrod length (I just assumed there wouldn't be any need for a shorter rod).
Any feedback would be appreciated, Ken
Old Oct 29, 2005 | 04:03 PM
RogueVette's Avatar
RogueVette
Cruise-In III Veteran
Was the car dyno'd on the same dyno each time?
Old Oct 29, 2005 | 04:07 PM
Ken G's Avatar
Ken G
Yes, this is the same dyno and SAE corrected numbers.
Thanks, Ken
Old Oct 29, 2005 | 06:08 PM
zeevette's Avatar
zeevette
I don't think your expectations were too high. From everybody else's experiences, that setup should yield at least 440 to wheels. Is it a Mustang dyno? Only 60 rwhp from a H/C is not a real great deal, although I have heard of people doing even worse. Also a switch to SVO#30 injectors may help.
Old Oct 29, 2005 | 06:39 PM
427CPE's Avatar
427CPE
ARP Head Studs
Stock rockers
Stock lifters
Ported LS6 oil pump
I think your expectations were too high. ALso, maybe you have a really honest dyno. Your headers/and others are not going to be able to scavenge the exhaust flow as much as with a tighter lobe center. 28 degrees spark seems like way too much. I'm thinking 24-25 max. I see 7.4" PR, but what is the rocker preload? I never go more than 1/2-3/4 turn. I think your A/F is perfect--I don't like em any leaner. The AFR "205" heads have less port volume than a stock LS6 head. I'm not sure this is good for max power production. Also, comp cams stuff really doesn't need degreeing. Their cams, at least the 2 or 3 I've checked in other motors were spot on within +1/2 crank degree. You might make a pass at the track and check MPH. Sometimes dynoes have been know to give the wrong data, if you know what I mean.
How does your data log look? Fuel trims, etc?
Old Oct 29, 2005 | 06:43 PM
427CPE's Avatar
427CPE
Easy w/the SVO Injectors.
1) The resistance of those injectors is different than the stock LS6 injector. 11 vs like 17ohms or so. This means the voltage offset table will need changing. Can be easily fixed I agree, just don't like them.
2) I have used these. After repeated run ups on a dyno, they tend to overheat and die. I changed to Lucas 30's and had MUCH better results in addition tot he fact that Lucas injectors have the same spray pattern and close to the same resistance as a stock injector. Thats my opinion based on using 19,24,30,36,42lb/hr SVO inj on other cars and 30's on my 03 Vette.
Old Oct 29, 2005 | 06:44 PM
Ken G's Avatar
Ken G
Unfortunately, this was on a dynojet. I think I'm still okay with the injectors (although I didn't actually calculate the duty cycle). The car was running very rich at the top end (A/F 11.8-12.1:1 from 6500-6800 RPM's) until we leaned it out a bit. I have a feeling that I may have to take the heads off and have them milled a bit to bring the CR back up. I just don't want to run into any piston to valve clearance issues.
Thanks, Ken
Old Oct 29, 2005 | 06:49 PM
99 The Hard Way's Avatar
99 The Hard Way
I have a 224/581 with stock LS6 heads on a 114 and made 389. I am also running 28 degrees. I would expect around 410-420 if I went to AFR's. I think you just went a little too mild on the cam for your expectations. 414 is nothing to be disappointed with. That's damn strong it it probably idles close to stock, like mine. It's hard to get the car to hook up with much over 400 anyway. This is just my opinion as I have been kicking around the idea of AFR's. You have a great combo, and I think 60 rwhp is damn good
Scott
Old Oct 29, 2005 | 06:56 PM
Ken G's Avatar
Ken G
We did try timing adv. as low as 26 deg. and worked our way up to 30 deg. (we stopped seeing improvement after 28 deg. so we set it there). I'll have to mention to the tuner about maybe trying lower timing advance. I didn't really think that the camshaft was off because the powerband is right where it should be. I really only have one good trip's worth of data logged and noticed that the LTrims dropped steadily from about +20 to +10. I'll log some more data but I'm going to bet that they have continued to drop.
As for going to the track, that is a big for me. The second I start racing again I won't be happy until I run a particular number. The only problem with that is that the number always gets lower every week .
Thanks, Ken
Old Oct 29, 2005 | 06:59 PM
Ken G's Avatar
Ken G
Scott
Scott, Thanks for the encouragement!
-Ken
Old Oct 29, 2005 | 07:27 PM
algZO6's Avatar
algZO6
i think your CR is hurting you. i don't think you were expecting too much, hell i dynoed 420 rwhp and 396 rwtq with a F13 cam and my heads have never been off the car. my car is also an 04 Z.
Old Oct 29, 2005 | 07:52 PM
Ken G's Avatar
Ken G
I'm sure this is a major part of the problem. I just have to decide if I want to mill the heads or not. My original plan was to go with a turbo kit after removing my A&A Procharger setup. I then changed my mind and decided to go with heads/cam for now and see the results from all of the new turbo kits over the next year.
BTW, those are great numbers for a cam car!
, Ken
Old Oct 29, 2005 | 08:10 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
it would be interesting to see if a larger cam(g5x3ish)would make up the difference in power, what's the CR w/ the new afr setup? i'll be going to westport tomorrow and there a dozen or so afr/cam/lt cars putting down 450rwhp, i'll have to see what which heads they are running
btw-interested in the westport gathering?
congrats on the install good to see other locals doing their own wrenching
Old Oct 29, 2005 | 08:34 PM
Ken G's Avatar
Ken G
Steve,
With the unmilled 66cc AFR's and the 0.04" Cometic gaskets on the stock bottom end, I think I'm running somewhere around 10.2:1 CR. If I had 0.024" taken off that would put me somewhere around 11:1 (I would need to run the numbers on smokemup.com to be sure). If you don't mind, ask around tomorrow and see what people are running.
Thanks for the invitation but we've got our neighborhood Halloween party for all of the kids tomorrow (I missed my two sons' soccer games today to go get the car tuned so I don't want to miss the party). I hope you guys have great weather!
, Ken
Old Oct 29, 2005 | 09:05 PM
rwj383's Avatar
rwj383
Lean out the AFR to 13.0:1, you might pick up a little more. other than that your numbers are commensurate to the cam you're using. If you're gonna pop the heads off to mill them for more CR then you might as well pop in a bigger cam. 232/240 .590 114 will fit without worries of p/v clearance as long as you dont take off more than .010 mill. Personally, I would leave the heads on and just do a different cam like the one I mentioned. That plus Speed Density tuning and you will yield sweet results.
Robert
www.gen3motorsports.com
Old Oct 29, 2005 | 09:06 PM
PHPD7102's Avatar
PHPD7102
St. Jude Donor '14-'15-'16
I think your about right on. I have LS6 heads not milled with 2.02/1.57 valves lightly ported/polished and bowl work done, my cam is 581/581 224/224 on a 115LSA and I was making 413rwhp 397rwtq using a LS6 manifold before I put in 4.10's.
Old Oct 29, 2005 | 09:22 PM
Ken G's Avatar
Ken G
Robert
Thanks for the advice. I guess I have a lot to think about here!
That's very helpful information for me. At least I know I'm in the ballpark.
Thanks, Ken
To H/C- Problem?
Old Oct 30, 2005 | 09:25 AM
BT-01-vette's Avatar
BT-01-vette
Contact ECS, mine was milled to 59cc's and I have basic bolt on's. I would think your results would be higher. Good luck
Old Oct 30, 2005 | 03:45 PM
Ken G's Avatar
Ken G
I'll probably have the heads done, although, I don't think I'll go down to 59cc. I'll probably stick around 62-63cc.
Thanks, Ken
Old Oct 31, 2005 | 09:42 PM
RogueVette's Avatar
RogueVette
I agree that you have less power the I would have expected.
I have old technology LS1 heads (Cartek stage II from 2000), small cam (218/222) average headers (FLP long tubes) and I got 409/390 on my 99 C5. With ARF's and a bigger cam I would have expected at least 20 more, though I do have a better CAI in my opinion (Vararam vs. your Blackwing) I would not think it would make up that much room.
