C5 repairs after 50K miles
Old Oct 29, 2005 | 07:22 PM
The Director's Avatar
The Director
Default C5 repairs after 50K miles
My 2002 C5 just past 50K miles. So far, the battery is the only thing I've had to replace other than tires.
For those of you over 50K, what kinds of things have you had to repair/replace? We talkin' or on the average?
Old Oct 29, 2005 | 07:48 PM
Nitro Junkie's Avatar
Nitro Junkie
2001 w/ over 70,000. Battery and fuel guage.
Old Oct 29, 2005 | 07:52 PM
vette1003's Avatar
vette1003
2002 Vert
67K and had to replace the Battery 2 times, Just replaced the DS rear axle seal and the A/C idler roller. Now the PSD contol module for the door locks. Not bad since I use it as my daily vehicle. Did all the work myself. I find it really easy to work on my Vette
Old Oct 30, 2005 | 02:56 PM
babalu95's Avatar
babalu95
Default '99 FRC 70k
My '99 FRC w/ 70k miles has needed the following repairs in the past year:
Harmonic balancer (initially we thought it was the idler pulley or belts)
Passenger side window motor
Blower motor
Column lock bypass (of course)
Sway bar bushings with end links
Oil pressure sending unit
Seafoam flush
That's about it. I love my car.
Old Oct 30, 2005 | 03:12 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Had to replace my battery last year and a headlight motor. 2001 with 54,000 miles.
Old Oct 30, 2005 | 03:13 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
180K and I've only replaced the clutch, slave cylinder and battery basically...and tires of course
Old Oct 30, 2005 | 04:47 PM
yankeevetteconvert's Avatar
yankeevetteconvert
02 vert. with 45k. Just replaced the front brake pads. Also replaced the battery two years ago.
Old Oct 30, 2005 | 04:58 PM
tolk's Avatar
tolk
'98 C5 72K miles. One rear wheel bearing, one CV joint boot, battery, tires, front brakes and rotors. I've owned 17 different cars in my life and this one is definitely the best all around performer maintenance wise and pretty much everywhere else. Did all the work myself.
Old Oct 30, 2005 | 10:07 PM
Joevette99's Avatar
Joevette99
Default '99 6 Speed, 76k
0. Bilstein shocks @ 25K..just because originals were fine
.5 Spark plug wires 30K
1. oil pressure sending unit at 60k
2. Three steering column locked repairs, two under warranty, 3 flatbed tows 23k, 48k, 65k... did not do the latest yet.
3. front disc and pads 72k
4. CLutch assembly (flywheel, pressure plate, disk, slave cylinder, throw out bearing at 76k
5. Trans and differential fluid replaced 76k
6. New catbacks and x-pipe...just to change sound at 74k
My car has been pretty sound...knock wood...
Old Oct 31, 2005 | 12:44 AM
JH's Avatar
JH
Now THAT is a testimonial
Glad to see you got a GOOD ONE! Hope I am as lucky!
Old Oct 31, 2005 | 01:18 AM
Dirty Howie's Avatar
Dirty Howie
51k ...... see sig for things I did not need to replace
DH
Old Oct 31, 2005 | 05:21 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
coming up on 70K....
battery
brake pads
changed fluids
had a muffler flange come loose....then cut the damn things off anyway 3 mos later
basically whole new drive train...first under warranty front part then starter took out flywheel so I got a new clutch assy last year....
rear end case cracked so I have a new Z06 rear
bad alternator early on.....
other than that on my 3rd set of tires and love my Vette
see sig for all the real necessary stuff
Old Oct 31, 2005 | 05:56 AM
Ben01C5's Avatar
Ben01C5
75,000 and I only replaced the stuff that wears, brakes, clutch, tires.
and the unnecessary stuff in the sig.
Old Oct 31, 2005 | 01:40 PM
fisherdm's Avatar
fisherdm
7th Gear
I have a 2001 vet with 34k miles. I had to replace (not under warranty)
the following:
Front wheel rim crack
hazard switch
brake pads
tires
head light motor
brake control module
ac leak behind compressor
Old Oct 31, 2005 | 01:48 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
156,000 but the way I drive, they are like dog years.
On its second battery, 4th set of brakes, maybe 6th set of tires, one AC recharge and second clutch.
Parts needing repair as of right now- Climate control display.
Old Oct 31, 2005 | 02:49 PM
FRC Rob's Avatar
FRC Rob
I've got 49k miles on my '99 FRC. Here's the list:
Battery
Tires
Adjusted Parking Brake
Fluids & Filters
Plugs & Wires
Reverse Light Switch
With the exception of the reverse light switch (which cost ~$20 and took 10 minutes to install), the rest is pretty much normal maintenance. This car has been very reliable!
Old Oct 31, 2005 | 05:16 PM
AJay's Avatar
AJay
2001 Coup / 25000 miles
Tires
Drivers Side Rear Axle Seal
To C5 repairs after 50K miles
Old Oct 31, 2005 | 05:26 PM
DallasC5's Avatar
DallasC5
2002 coupe 54,000 miles and replaced the following:
1. Battery
2. Brake pads
3. Sensor (active handling problems)
This is my DD and has proven to be a very reliable car.
Old Nov 1, 2005 | 07:54 PM
beltfed21's Avatar
beltfed21
I know you asked for the over 50,000 miles, but I couldn't resist posting a reply about the VERY COMMON left rear axel seal leak. My 2000 coupe with 35,000 miles on it is in the shop right now to get this fixed. Other than that, It is on it's second battery and second set of tires, and I've done routine fluid changes (oil every 3000. trans, radiator, and rearend at 30,000). I drive it year round, so it sees all kinds of weather conditions. Enjoy your vette.
Old Nov 2, 2005 | 07:22 AM
Fastguy's Avatar
Fastguy
Fogot about that, on the 3rd one!
