door panel removal???
Old Oct 30, 2005 | 05:38 PM
Billythekid47960's Avatar
Billythekid47960
Default door panel removal???
Trying to remove door panel on a 98 vert. I have removed the pw, pl, switch. Also removed the two torx head screws by the arm rest. How does the bezel around the handle come apart? Are there any fastners behind it? What about the speaker grille and any other hidden fastners?
Next question. How do you do the magnet deal to reset the tire monitor system. Looked in the owners manual and it said see dealer. The car has had tires changed before. Right rear is the only one not reading. Even changed valve stem/ sensor with last set of rears with no luck. Service tire monitor system displays on the dic all the time.
Thanks for any help you send my way.
Old Oct 30, 2005 | 05:44 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Very good instructions with pics for door panel removal here:
http://www.vetteessentials.com/instr...or_handle.html
The tire pressure sensor retrain procedure is explained here:
https://www.corvetteforum.com/techti...D=77&TopicID=1
Old Oct 30, 2005 | 06:22 PM
Billythekid47960
Thanks Y2kvert!!!!! This a great site!
To door panel removal???
