Wiring diagram...
Old Oct 31, 2005 | 01:33 AM
24hr Z06's Avatar
24hr Z06
Default Wiring diagram...
After running through the typical checklist (replace, 02 sensors and maf, pulling spark plugs, checking 02 sensor wiring, swapping 02 sensor wires, pulling the 02 sensors in the front and learning that the car runs fine w/out the 02s)..
P0171 Fuel Trim System Lean bank 1-B
Ive come to the conclusion that its time to replace the wires from the 02 sensor to the ecu.. I really can't think of anything else.. After swapping the 02 sensor wires in the front, and watching the problem follow, Im pretty certain that its a bad line, and not mechanical..
I was just wondering if anyone had a wiring diagram that I could check out..
