Dimming Headlights
Old Oct 31, 2005 | 08:41 AM
rc51racer's Avatar
rc51racer
Default Dimming Headlights
After start up on my 99 coupe I notice that my headlights within a minute or so will dim and then go back to normal. It then usually does this a few more times. Now I have been running the Auto mode for the HVAC and the compressor is on. I read a post earlier in the week about a loose ground wire under the battery tray. Well guess what I found when I removed the battery tray? A loose ground on a small nut that is on the frame rail. It has two wires connected to it. One is coming from the neg. on the battery cable and the other looks to be coming from the fuse box. I will test drive later today a let you guys know if it helped. Jim
