gas tank removal
Old Oct 31, 2005 | 10:54 AM
algZO6's Avatar
algZO6
Default gas tank removal
well do to an unfortunate amp mounting incident, the shop that installed my system drilled a small hole in my tank and now i have to replace it. how hard is it to remove it on an 04. thanks.
Old Oct 31, 2005 | 11:07 AM
boatboatboat's Avatar
boatboatboat
For a GM master tech with a lift and tools and all that jazz, you are looking at about 8 hours total labor.
I have an 04 and it had a leaky drivers side tank, and it was replaced under warrenty.
MAJOR pain in the back side.
Old Oct 31, 2005 | 11:22 AM
rws.1's Avatar
rws.1
Wow... 8hrs...
I hope the audio shop if footing the bill!
Old Oct 31, 2005 | 11:25 AM
boatboatboat
the whole drive train has to be removed...... It's unreal. When they were 1/2 thru with my car, I stopped at the dealer to have a look see.
OH MY.........
Old Oct 31, 2005 | 11:38 AM
Tigershark3's Avatar
Tigershark3
That brings up another question.... Is the fuel pump located in the tank? If so is it a major pain to change?
Old Oct 31, 2005 | 11:39 AM
kromberg's Avatar
kromberg
I removed both of mine in about one hour
Keith
Old Oct 31, 2005 | 11:50 AM
boatboatboat
you did?
My car is a vert, maybe that makes a diff? but i doubt it.
Old Oct 31, 2005 | 03:18 PM
BHP's Avatar
BHP
Keith
Late 2003-2004 are totally different (FFS tanks used on C6). Drivetrain has to come out. Not fun. Now if i can find the engineer that designed this I would have him do the work.
Old Oct 31, 2005 | 03:53 PM
GrayC5's Avatar
GrayC5
You can find more info on the redesigned FFS fuel system at the following link. One tip on Removing Fuel Tanks at the following link says, "Once you have performed this procedure, you will gain enough knowledge of the components that you may be able to do the procedure in the future without lowering the driveline." But for us that don't do this for a living everyday, plan on lowering the driveline. Good luck with the fix.
Redesigned FFS Fuel System
Old Oct 31, 2005 | 04:29 PM
algZO6's Avatar
algZO6
well, the stereo shop just cut me a check and a buddy (very experienced mech.) are going to do the work. since it is a small hole can it be patched?
Old Oct 31, 2005 | 08:50 PM
LS9's Avatar
LS9
stick a screw in it
To gas tank removal
