Help - Headlight or Electrical Problem?
Old Nov 3, 2005 | 12:36 AM
Trojan FRC's Avatar
Trojan FRC
Default Help - Headlight or Electrical Problem?
Guys, I'm lost as to what is happening with my headlights. A few weeks ago my left low beam went out. I replaced it tonight, tested it out a few times before I put the assembly back together and it worked fine. Then when I got it back together and went to take it for a drive, the same left low beam didnt come on after I started the car up. I'm trying to figure out what could be the reason. Any ideas? thanks for any help.
Info on setup
C5 9006 headlight
Competition Limited wiring harness with relays to run high wattage bulbs and highs and lows at the same time - it's directly hooked to the battery
first blew a 80w 9006 bulb and then the 85w 9005 modified to fit 9006 - the second bulb had no discoloration and both bulbs appeared to have fully intact filaments
