Tire Pressure Sensor Reading Wrong
Old Nov 3, 2005 | 02:59 PM
fms98's Avatar
fms98
5th Gear
Default Tire Pressure Sensor Reading Wrong
Have a 99 C5 FRC. As of a sudden I pick up a RF low tire pressure code that indicates 22psi cold and goes up to 24 when warm. Physically checked the tire pressure with a good gauge and find it @ 30psi. Remaining three wheels register correct to the gauge reading.
This a bad sensor,? Or is there some means to recalibrate the sensor. Any help appreciated.
Old Nov 3, 2005 | 03:05 PM
BlueDragon's Avatar
BlueDragon
I don't think there is a recalibrate, you need to get a new TPS.
Old Nov 3, 2005 | 07:26 PM
GeorgieMporgie's Avatar
GeorgieMporgie
http://forums.corvetteforum.com/show...r&forum_id=103
Old Nov 3, 2005 | 07:40 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
You can NOT recalibate the sensors. If you KNOW it is reading bad, then it needs replacement.
Old Nov 3, 2005 | 08:03 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I was having low readings for several months. Got oil change and the guy aired the tires to 32 and sensors magically read the correct pressure.......went home and with a good gauge took them all down to 29 which is where I like them... Sensors read the correct pressure now. I don't get it but that's the way it happened.
I'm thinking if you fill the tires to say 40, drive home, let air out and check with an accurate gauge at say 30... maybe the sensors will read correctly? Very weird...........
Old Nov 4, 2005 | 10:46 AM
fms98's Avatar
fms98
5th Gear
You folks are great. The relearn proceedure corrected the problem.
Old Nov 4, 2005 | 01:14 PM
604_c5's Avatar
604_c5
hahahaha i was waitin for this thread cuz im having same problems,
so ur sayin if i pump them up to 40, drive hom, let air out, check with gauge to 30, the weird TPS will read correctly?
To Tire Pressure Sensor Reading Wrong
