Has any one had ELECTRICAL PROBLEMS with ls2-C5 CONVERSION??
1998 Corvette, LS2 engine SEEM TO HAVE PROBLEMS WITH (Crank position Sensor and Cam position Sensor). Started with PO 336 & 339. did some wire swaping on cam Sensor now I got PO 342 Cam sensor code...
It will run for awhile dies, back fires won't start &&&& ECT.
Does anyone know the fix. What is the right wiring configuration for the Cam Sensor wireing?? red to red / pink to pink / Brown to Brown...Orrrr?
Origninal plug has wireing backwards from the LS2, Cam Sensor pig tail.
LS2 BLOCK, CALLIES CRANK... Is there an issue with Callies Reluctor Wheel maybe.
check continuity of wiring, make sure bracket on timing cover is secure for cam sprocket pick/up; i just did a ls2 cam swap a few weeks ago, i can ck the colors on sat. when i see the car again
