had my car dynoed over the week.. the car seems to fall everytime it reaches ~5300 RPMS all 3 pulls for just a bit. same time, same drop same RPM.. mainly in 4th gear.. on the highway, if i stand on it in 4th, when i reaches ~5300 RPMS, it feels like i took my foot off the gas..bogs pretty bad...but 1st, 2nd, 3rd pull to 6000 RPMS with no problem. during the run, when it drops, some fuel comes out the driver's side tail pipes. no check engine lights.
the car has NO tune as of now. is this more of a tuning problem, or should i start looking at somewhere else? other than that problem, the car runs fine
After a help from forum member Fallen ( BIG THANKS!!!! ), we were able to read my computer with his HP tuner.. at that RPM and gear, the computer shows 5 degrees of knock retard..the car falls out pretty hard... i can only assume that the car needs a tune to straighten this out?
vinnie, swap out the knock sensors, the intake manifold comes off in about 15 minutes and you could 'borrow' one from one of your buddies cars; almost sounds like the sensors are p/u some frequencies the headers may be producing?? no cracked springs?
