Dumb clutch question
Old Nov 5, 2005 | 10:48 PM
Jerseyvinny's Avatar
Jerseyvinny
Default Dumb clutch question
Is the LS6 slave cylinder, master cylinder and clutch kit bolt in upgrades for my stock '99 clutch ? If so, can the original flywheel still be used? Thanks in advance.
Old Nov 5, 2005 | 11:06 PM
Jserman's Avatar
Jserman
master and slave yes..... not sure about the rest
Old Nov 5, 2005 | 11:34 PM
jmzvet's Avatar
jmzvet
Look into the new LS7 clutch components. Not much more $ but well worth it. Installed one yesterday. PM "unstressed" and he'll fill you in on the details and performance.
Old Nov 6, 2005 | 02:22 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
GM LS6 Clutch Assembly comes complete with the fly wheel.
Old Nov 6, 2005 | 11:25 AM
Jerseyvinny
Thanks guys. So the LS6 clutch is a direct bolt in replacement in my '99? Just swap one for the other?
Old Nov 6, 2005 | 12:39 PM
unstressed's Avatar
unstressed
I don't know why anybody would consider an LS6 clutch assembly.
The LS7 Clutch is a drop in upgrade. Use the LS2 flywheel and LS7 disc and pressure plate. Upgrade your slave to a LS6 slave and you have a clutch that feels like stock but will handle over 500 HP.
All the parts mentioned (Flywheel, Disc, Pressure plate, slave) are ~$625 shipped from Gene at Fred Beans (Supporting Vendor).
Forget the LS6 clutch. Besides, many have replaced the LS6 clutch and still had the "pedal stick to the floor" problem.
Old Nov 7, 2005 | 07:12 AM
WKMCD's Avatar
WKMCD
I've had mine for about a month.
Old Nov 7, 2005 | 04:11 PM
DRR's Avatar
DRR
Vinny, the answer to your question is yes. They are a direct replacement. What ever you end up using be sure to get a remote slave bleeder from LAPD. I use my once a month to always keep fresh fluid in the slave cyl.
Old Nov 7, 2005 | 09:47 PM
Jerseyvinny
Thanks, At least now I have a plan.
To Dumb clutch question
