Cartek Line Lock
Does it not matter which wire from the solenoid gets grounded? Im gonna go out on a limb and say no but wanted to confirm with you guys first..
Thanks..
dont you pump the brakes, press the button and then dump the clutch? If I did it your way I would go flying forward....
I know, Ive gone mad, but what can you do, it was driving me crazy but serenity now.... BTW.. If the car isn't running with the 02s plugged in come Nov. 21.. Shes getting raced as is...With that in mind... Ill be more then happy to install your linelock for you.. Just tell me when and where.. All I require is some beef on a stick, no beer just food, and a good clean working environment..
BTW to all the drag racers, I HIGHLY recommend this.. I never had a problem doing a burnout but this makes life 1 MILLLLION times easier AND as a bonus its easier on your rear diff, and rear brakes.. So worth the $250..
Bob.. I dunno what to tell you.. Next time I do a burnout ill give your method a try and see what happens.. maybe ECS jerry rigged yours and its backwards.. KIDDING KIDDING... Whos line lock do you have? Id think youd want to press the button in order to activate the lockup, Id hate to get a lockup while driving around on the street..
I agree that you have to push the button for it to work. My thought was that you pump the brakes and get them firm then you hold the button to lock the front brakes at that point.
If you hold the button first then you would activate the brakes at the current setting which would be with no pressure.
One test is to not have your foot on the brake and just hit the line lock then pump the brake. See if it holds from there. I have had my front tires move when I have not had the brakes firm enough....
Of course Chris told me what to do so who knows
.. Mine has an on/off switch, so it might be different then yours, no need holding a button..
Every line-lock I have ever used works like a check valve when activated. When activated you can always add more brake pressure, it just don't come back through the line-lock until you deactivate the lock. Even the really old mechanical ones on the really old dump trucks worked like this, except they normally locked the back brakes or all the brakes.
You took the words right out of my mouth
Once done you can just push the button and hit the brakes at any time and they will stay locked untill you release the button... you can also play around with driving down the road at 20-30mph and hold the button the slightly tap the brakes while simotaneously mashing the throttle and do a major top fuel burn out while driving down the road!! quite impressive to those who don't know you have line lock!! I hope some of this helps those who have never installed one before.
max
well that makes sense why either method would work...
max
Click Here for photos of a similar install of a Hurst Line-Lock.
Last edited by SpeedyZ; Jun 13, 2019 at 10:02 PM. Reason: Updated URL for new server
Thank you...
