Wont shift into first on occasion...
Old Nov 7, 2005 | 03:58 PM
Goonie's Avatar
Goonie
Default Wont shift into first on occasion...
1 out of 500 times, when i shift into first out of neutral from stop, it wont go into the 1st gear. I then have to shift it into 2nd and without letting the clutch go, rev it a tad to spin the tranny, then itll let me shift into 1st.
Does this happen only to me?
Old Nov 7, 2005 | 04:14 PM
unstressed's Avatar
unstressed
Common issue, also occurs trying to get into reverse. Need to rock the car a little get it into gear.
Old Nov 7, 2005 | 05:28 PM
CSC5's Avatar
CSC5
From: Yeah, well, you know, that's just, like, your opinion, man.
Happens to me as well.
Old Nov 7, 2005 | 05:32 PM
coast7's Avatar
coast7
Used to happen to me, but I changed trans & diff fluids to synthetic when I installed the C6 shifter...now it goes in smoothly and doesn't pop out unexpectedly. Sounds kind of erotic
Old Nov 7, 2005 | 11:35 PM
JT-WI's Avatar
JT-WI
1st Gear
My first post!!
I just bought a '99 C5 that pops out of first more often...50% of the time. Syncros? Any thoughts where to begin to troubleshoot?
Old Nov 8, 2005 | 01:17 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Originally Posted by JT-WI
My first post!!
Oh my!! Years ago this meant you had worn gears and all you can do is replace them... I used to have a Muncie 4 speed that did that... pop out of gear under hard acceleration... it sucked!!
I don't know if it still means the same thing? Others will chime in...
To Wont shift into first on occasion...
