Rear end/Diff. leak... Can we set up a Poll for this?
Old Nov 8, 2005 | 10:22 PM
nmbsun's Avatar
nmbsun
Default Rear end/Diff. leak... Can we set up a Poll for this?
My 2004 C5 started leaking from the diff/ rear end at 6,500 miles. Its fixed now with a new seal but from what I understand it can and will happen again. I would like to set up a poll here so those that have this problem can state their problem and then hopefully if we get enough response we can get GM to address this problem.
Old Nov 8, 2005 | 11:49 PM
Vette#2's Avatar
Vette#2
AMEN!
Mine did the "leak" also. The dealer said they installed the "new type" seal
PS: Cost was $1100.......... and they did both axle seals also " since we had it apart"
Old Nov 9, 2005 | 12:22 AM
az57chevy's Avatar
az57chevy
My 2003 with 12K miles goes into the shop tomorrow for the left side leaking
Old Nov 9, 2005 | 08:23 AM
mike348's Avatar
mike348
My 04 had a new cover and seal put in at 10,000 miles.
Old Nov 9, 2005 | 08:54 AM
99vettecoupe's Avatar
99vettecoupe
My 03 Z06 had both axels and the cover done at 20k
Old Nov 9, 2005 | 09:05 AM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
My factory 3.15 in my 98 never leaked. Put in a Getrag 3.73 and it was leaking at 5k. Dealer repaired, has not leaked since. I remember it being a spendy fix as well.
GM is not going to do anything about this.
Old Nov 9, 2005 | 01:40 PM
Digmo's Avatar
Digmo
Default diff leak
My 04 vert was leaking at 11,000 miles replaced seal and new style O-ring. Leaked again at 23,000 miles replaed aboe plus diff cover plate. OK past 1,000 miles. I think that GM should be giving free extended warranty on this item.
Ray
Old Nov 9, 2005 | 05:26 PM
Nick Williams's Avatar
Nick Williams
Are you guys sure that they aren't leaking thru the vent on the left side? I personally don't think that the factory vent is enough so I put a bigger vent in and haven't had a leak since.
Old Nov 9, 2005 | 05:28 PM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Why start a poll. Just figure out how many Corvettes have been made and that will be how many leak. I have seen this problem too many times.
Randy
Old Nov 11, 2005 | 07:05 PM
beltfed21's Avatar
beltfed21
My 2000 automatic coupe with 35,000 miles on it just had the left side rear end leak repaired at a cost of $450. It was not done by a dealer, but by a trusted transmission shop. They said the leak was actually from above the seal and was from the diff cover, but they put on the revised seal and o-ring while they where in there. The right side seal was not leaking at all, so they did not have to drop the rear-end down - that would have been at least $1000.
Old Nov 11, 2005 | 07:15 PM
Gene Moses's Avatar
Gene Moses
2002 C-5. Left side leak repaired at 17,000 miles.
Old Nov 12, 2005 | 06:16 AM
mutts2's Avatar
mutts2
Default Mine Too
3 days ago saw a small leak on Left side (2002 - 32,000 mi) Dealer says 90% occur on the Left and doesn't know why.
Will have it repaired before winter....first time to use my extended warranty.
Old Nov 12, 2005 | 06:21 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Y2k with no leak at 18000 miles...yet, but If im going to fix a leak for $1100.oo im fixing it with a new rear and gears from DTE
Old Nov 12, 2005 | 08:39 AM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Installed a new 3.42 Getrag in my '98 in 2000. Fortunately, no leaks so far....
Old Nov 12, 2005 | 08:42 AM
c-5-steve's Avatar
c-5-steve
00 vert with a-4 left side leaked @ 8000 miles
Old Nov 12, 2005 | 08:48 AM
JEEP/C5's Avatar
JEEP/C5
left side leaked at 28,000, fixed it myself for $50.00 total. Took 5 hours but an hour of it was cleaning all the grease from the underside. Repair it your self if you ever done a front wheel drive axle shaft. Not any harder - just a little different. I printed out a how to off of the forum.
Old Nov 12, 2005 | 08:52 AM
docbrew's Avatar
docbrew
00 vert, left side leaked @ 28,000 miles.
To Rear end/Diff. leak... Can we set up a Poll for this?
Old Nov 12, 2005 | 09:00 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
My 99 roadser was fixed twice for leaking on the left side. The last fix was done around 25000 miles ago and still not leaking.
Tom
Old Nov 13, 2005 | 02:57 PM
Beardown3's Avatar
Beardown3
Default Mine just started leaking
I'm at 108K, so I guess I've been lucky till now
Old Nov 13, 2005 | 04:36 PM
binkysgarage's Avatar
binkysgarage
50k no leaks and has never been replaced.
