Rear Knock Sensor- DTC PO332
Old Nov 10, 2005 | 08:33 PM
michaelj_h's Avatar
michaelj_h
Default Help! Rear Knock Sensor- DTC PO332
Does anyone have any experience with the DTC code PO332, Rear knock sensor?
I have a Service Manual for my 99 FRC, but haven't found a clear path to take as far as remedying this problem. It is the only code I have, and am wondering if I can dig into this and fix it without removing the intake manifold? Also what, all in all should I do?
Advice would be much appreciated!
Thx.
Old Nov 10, 2005 | 09:17 PM
cbjetboy's Avatar
cbjetboy
I had the same codes P0332 and P0337, I believe. I had to have both of my knock sensors replaced. It apparently is common for water and oil to get in there and cause corrosion. My technician said that they always put a silicone dam in there to avoid future corrosion. It took removal of the intake manifold, (2) 12589867 Sensors, (1) 12533587 Gasket Kit and (1) 12346141 Adhesive. Hope this helps.
Old Nov 11, 2005 | 07:51 PM
michaelj_h's Avatar
michaelj_h
Default Thanks so Far, Anymore Help?
Thanks Guys, Anybody else have insight into what I need to do??
Can you access the knock sesnsor leads without removing the intake manifold?
To Rear Knock Sensor- DTC PO332
