My steering has play in it
Old Nov 13, 2005 | 01:16 AM
jhong321's Avatar
jhong321
Default My steering has play in it
Hello All. Need a little help.
I have a 2000 frc and the steering seems to have a little play in it. I have read that there is a bolt that needs to be tightend to get rid of the play but i am not sure what it looks like and where it is. Can someone help me find it
Jerome
Old Nov 13, 2005 | 09:47 AM
konish's Avatar
konish
Jerome,
My 01 coupe had the same problem..say 3/4" of rotational play at the steering wheel. Look into the engincompartment on the drivers side and follow the steering shaft until you get to a simple, folded steel bracket. There is a pinch bolt (I *think* its 13 mm) that needs to be tightened. I would hit it with a little PB Blaster oenetrating oil or something similar before tightening. Mine only needed about 3/4 of a turn and it snugged right up.
R/
Dustin
Old Nov 13, 2005 | 12:32 PM
jhong321's Avatar
jhong321
Thanks you Dustin Thats what i was looking for..
Jerome
To My steering has play in it
