Oil level a little high
Old Nov 14, 2005 | 12:41 PM
esmachers's Avatar
esmachers
Default Oil level a little high
I changed my oil last night and ended up with a reading on the dipstick that is high, i.e., it appears to go above the "hash" marks.
When refilling with that last 1/2 quart of oil my method is to enter a little then check the dipstick; then enter a little more then check the dipstick, etc. Somehow that last little bit seemed to unexpectedly put me over the top.
If I had to guess I'd say it's about 1/4 of a quart high, tops.
Should I drain some oil out or leave it as is?
Thanks in advance.
Old Nov 14, 2005 | 12:52 PM
ErnieN85's Avatar
ErnieN85
it's ok
Old Nov 14, 2005 | 01:20 PM
VetteDrmr's Avatar
VetteDrmr
GM recommends running a quart overfilled if you are autocrossing or tracking the car, and there's no problem with leaving that quart in. So, no problem with being 8 ounces over.
My normal fill now is 7 qts.; much rather be over than under (but again, I autocross).
HTH, and have a good one,
Mike
Old Nov 14, 2005 | 02:58 PM
esmachers's Avatar
esmachers
Thanks for the help guys. I'm leaving it as is.
Old Nov 14, 2005 | 03:19 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
its better to be a little over and a little under !
Old Nov 14, 2005 | 04:25 PM
rws.1's Avatar
rws.1
I put in 7 quarts lasty week and it is still only half way up the hash marks....
Old Nov 14, 2005 | 04:28 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
I always put 7 quarts.
Old Nov 14, 2005 | 05:24 PM
dpd's Avatar
dpd
it all depends on how and how long you let it drain.i drain my car level and let it drain for about 20 minutes.after it takes about 7 to 7 1/4 to fill to the top of the hash[2nd dot].note: i prime my oil filter prior to putting it on[1/4 quart].
Old Nov 14, 2005 | 06:28 PM
SLPRC5's Avatar
SLPRC5
just changed mine and 7 qts is the NORM...
Old Nov 14, 2005 | 06:54 PM
z06matt's Avatar
z06matt
Yeah you should be fine!
Old Nov 14, 2005 | 10:17 PM
beltfed21's Avatar
beltfed21
Default oil must be warm before checking or it looks overfilled
I'm probably just a stupid female, but in other cars I often checked the oil with the engine completely cold. (maybe this was wrong?) So one morning after the dealer changed the oil in my C5, I checked it and found it to be way overfilled. This made me really mad, since I've always heard that overfilling is really bad. I was almost ready to call the dealer and bitch, but I decided to read the owner's manual first. It said the engine must be fully warmed up. So I started it up and let it run for 5 minutes, then I shut it off for about 2, just to let the oil drain off of the stick. I checked it and it was exactly to the right level.
Old Nov 15, 2005 | 01:59 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
WOW...I gota find my manual. I didn't know that....
Old Nov 15, 2005 | 08:19 PM
Beezvette's Avatar
Beezvette
I have an 01 and my results are exactly the same as yours.
Old Nov 15, 2005 | 08:50 PM
David426's Avatar
David426
7 Quarts Always
Old Nov 15, 2005 | 09:25 PM
nmbsun's Avatar
nmbsun
I have never heard that before! I have an 04 and I drain the oil at an angle to get all the oil out 'rear higher than the front', and it always takes 7 qt. to bring it to the fill mark. Cold or hot it reads the same!
If you dont mind what page is that on in the owners manual?
Old Nov 17, 2005 | 08:28 AM
beltfed21's Avatar
beltfed21
In the 2000 owners manual on page 6-12 it says:
In order to get an accurate reading, the oil must be warm and the vehicle on level ground. Do not check the engine oil after the engine has been sitting overnight. A higher than normal reading might be obtained. Check oil level with the oil warm.
When cold mine shows about 1/2 quart or more overfilled, even though when warm it is exactly right. We also noticed this to be true in my husband's 01 vert, but I have not checked his owners manual to see if it still says the same thing.
Old Nov 17, 2005 | 08:00 PM
Patman's Avatar
Patman
I pour in 7.5 quarts of oil when I change my oil, and I don't even raise up the back end to get that last 1/2 quart out of the oil pan either (so it's almost like I'm running 8 quarts of oil)
I've seen no ill effects, my engine does not use any oil and my oil analysis results are excellent.
Old Nov 18, 2005 | 12:09 PM
esmachers's Avatar
esmachers
Great help all and interesting news about the Owners Manual statement on checking the level with the engine warmed up. I guess I've done it that way out of habit.
BTW, my boat's engine is a GM 5.7L marinized by Crusader and they REALLY emphasize not overfilling the oil. This is probably due to the operating conditions, e.g., angle while getting up on a plane, wave action, etc. Also, the use of synthetic oil voids the warranty. They are very picky and I'm very careful with it.
Thanks again!
To Oil level a little high
