Bad oil sending unit.
Old Nov 14, 2005 | 09:27 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Default Bad oil sending unit.
Ok, either my pump has been secretly swapped out or my sending unit is bad since I seem to have 102 psi. The search function is dead so I need to know where the oil sender is. Please tell me its not behind the intake near the firewall.
Old Nov 14, 2005 | 09:46 PM
vette747's Avatar
vette747
Sorry, Yes it is.
oil pressure sensor
Old Nov 15, 2005 | 12:10 AM
Rob Petyo's Avatar
Rob Petyo
and...it's an 1 1/16" deep socket NOT an 1 1/8"
It's fun...I did mine on Saturday.
Old Nov 15, 2005 | 09:55 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
I got you beat
Mine is reading 130psi I just saw this yesterday, but it is due for an oil change. I was hoping that would clear it up.
Old Nov 15, 2005 | 10:07 AM
2kbluestreak's Avatar
2kbluestreak
Along with column lock, rocking seat, leaking battery, etc, etc, etc, this is the latest universal problem to show up!
Old Nov 15, 2005 | 11:23 AM
Var's Avatar
Var
I have a customer who wants this problem fixed but he was afraid it was going to take forever...and he expressed his unwillingness to have the job done in such a way that i didn't even bother looking up the book time!.. Now i can quote him a realistic time to do the job. Thanks.
Old Nov 15, 2005 | 11:36 AM
lost's Avatar
lost
Although it is not as simple as most are, it is not as difficult as many make it out to be. Intake manifold does not need to be removed, just loosened and slid back an inch or so, to access the sender. A competant mechanic can do this job in less than an hour.
Old Nov 15, 2005 | 01:21 PM
Fastguy's Avatar
Fastguy
Cool, so that means I should have it done in a few hours.
Is this a dealer only part?
Old Nov 15, 2005 | 02:54 PM
TSDuke's Avatar
TSDuke
I've got an extra one at the house I can send you. It's used, but works perfectly, pay shipping & it's yours.
Old Nov 15, 2005 | 03:40 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
is it safe to drive the car in this condition?
Old Nov 15, 2005 | 03:45 PM
muncie21's Avatar
muncie21
Yes, until your pump really takes a dump on you, cause you won't know until the motor is toast.
Old Nov 15, 2005 | 04:23 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
i drive 2 hours every day. I am not sure what the actual job function is other than a sensor.
Someone please fill me in so i know for sure to ground my car untill the weekend or not.
thanks
Old Nov 15, 2005 | 04:40 PM
muncie21's Avatar
muncie21
You can drive with a bad sensor (I did for about 3 weeks) but you won't know if your oil pump takes a dump. I've heard about early Z06's having low pressure due to foreign stuff keeping bypass valve open
Old Nov 15, 2005 | 04:43 PM
vectorz's Avatar
vectorz
You guys should really go through my DIY guide posted above. It's a lot easier than you guys think.. should take about the same time as doing an oil change.
Old Nov 15, 2005 | 04:51 PM
muncie21's Avatar
muncie21
Agreed! I used the guide to change mine out. First time it took about 2.5 hours, second time about an hour, including beverage breaks.
Old Nov 15, 2005 | 10:13 PM
turboc5's Avatar
turboc5
I've noticed with mine it reads exactly dubble on the digital read out. So a little quick math in my head and i know whare my psi is at, just in case I loose my oil psi.
Old Nov 15, 2005 | 10:26 PM
muncie21's Avatar
muncie21
Top end of the scales are different. I.E. gauge maxes out at 60 PSI, DIC maxes out at 120. Either way those readings aren't correct. If the scales maxed out at the low end,what would happen?? Double zero (0) is still zero Just teasing, anywho, get the sending unit fixed, it could help one day.
To Bad oil sending unit.
Old Nov 16, 2005 | 12:01 PM
Rob Petyo's Avatar
Rob Petyo
Old Nov 16, 2005 | 12:05 PM
TSDuke's Avatar
TSDuke
My offer still stands. I have a sending unit that I'm willing to give someone, just pay shipping. These badboys are not cheap.
Old Nov 16, 2005 | 01:46 PM
vectorz's Avatar
vectorz
TSDuke, I'll take it
