Tire Pressure Sensor
Old Nov 15, 2005 | 10:32 AM
TheBigDog's Avatar
TheBigDog
Default Tire Pressure Sensor
Can someone tell me what the torque specs are for the pressure sensor?
Thanks,
The Big Dog
Old Nov 15, 2005 | 12:22 PM
diviniti's Avatar
diviniti
St. Jude Donor '05
Tight enough so it doesnt come loose? I dont think they need much. Just give the nut a little oomph crank and it should be fine.
Old Nov 15, 2005 | 12:59 PM
GUSTO14's Avatar
GUSTO14
I use a 1/4 inch drive screwdriver like extension with a deep socket and tighten them this way so as not to overtighten them. Remember they have an O-ring that does the sealing and you don't want to distort it too much.
GUSTO
Old Nov 15, 2005 | 04:56 PM
nmbsun's Avatar
nmbsun
Thanks,
The Big Dog
This is from the C5 2004 Gm service manual. "Torque tire sensors to..
7n-m which = 62 lb.in = 5.16 lb.ft."
PS: Use a 12mm deep socket to torque the tire pressure sensor...
Old Nov 16, 2005 | 09:52 AM
jimcork1's Avatar
jimcork1
I put a light film of oil on the o-ring to help seal, then I just hand tighten gently. Never had an issue. I guess the wrist just clicks when it is right.
99 Nassau blue
To Tire Pressure Sensor
