Braided lines from master cylinder
Old Nov 15, 2005 | 11:19 AM
TheLaserShop's Avatar
TheLaserShop
Default Braided lines from master cylinder
Would like to run braided stainless lines from the master cylinder to the ABS unit. Gets very confusing trying to piece it all together. I dont really know for sure what the sizes are. Would anyone know which fittings/hose size/adapters????? I would need? No one just makes a kit for this. Info or part numbers would be helpful.
Thanks, RonO
Edit: '97 Vette'
Old Nov 15, 2005 | 12:33 PM
dmtnt's Avatar
dmtnt
St. Jude Donor '03-'05-'06 & '12
Hmm, the lines on my '02 Z06 are braided from the factory.
Old Nov 15, 2005 | 12:58 PM
TheLaserShop
Off the master cylinder?
Old Nov 15, 2005 | 03:33 PM
dmtnt's Avatar
dmtnt
Yep, the two lines that run to the ABS unit.
Old Nov 16, 2005 | 07:51 AM
TheLaserShop
Anyone have a part number(s) on that?
Old Nov 16, 2005 | 11:04 AM
SpeedyZ's Avatar
SpeedyZ
I think the factory had a short (six inch) braided section in the middle of the hard lines. That is the way my 01 Z06 is made, I don't know about other years. The problem I had when trying to install a Line-Lock was I could never find a fitting that fit the rear port on the master cylinder. The best I remember it was 12mm x 1.5mm bubble flare. I found all kinds of fitting that would fit the front port which was a finer thread, but nothing for the course thread rear port. The factory line size is 6mm which is just under the US standard 1/4" lines.
To Braided lines from master cylinder
