Is this the cure for running no tire pressure sensors?
I just swapped out my tires and wheels to make a trip south, on my 1997 C5. The wheels I took off had the tire pressure sensors in the wheels.
The wheels I replaced them with does not have the TPS installed in the wheels. The valve stems in these wheels are "rubber valve stems".
It seems the DCI does not register the tire pressure because of the rubber valve stems. SO no annoying warning sound goes off, or a showing of lack of tire pressure readings. Has anyone else tried this?
Rsty
Rsty
This is very intersting I am about to change out rims and tires and was thinking about not using the Tires sensors since 1 is already out and I don't see a problem not running them. Please keep me informed on what happens after 100 miles on them..
Jerome
I certainly will. I have 25+ miles on it now and no message so far...I was just not wanting the annoying bell and message everytime you start up..so we'll see. Thanks for your interest..
Rsty
I have a Y2K, and drove it for weeks, many hundreds of miles, without pressure sensors. No bells or warning messges. If I called up tire pressure on the DIC it read xxx, but no other issues.
Thanks for that positive input...this up coming trip will let me know if there is no problem with running without TPS.
Rsty
I swap back and forth between stock wheels with sensors and Z06 track wheels with no sensors. Around town the sensor warning never goes off since I come back to the garage where the wheels with sensors are stored. If I get 40 + miles away and some times up to 100 miles it finally goes off and then continues to do a start up warning until I get back home. It usually gives warning for all four tires at same time but once it kept reading for one wheel longer than others, no idea why.
Randy
