Ported oil pumps ?
Old Nov 16, 2005 | 04:52 PM
2002 MATRIX SC's Avatar
2002 MATRIX SC
Default Ported oil pumps ?
I was thinking about upgrading to a ported and blueprinted oil pump, are they any better than the stock unit? I heard this was a weak point on are motors. Matt.
Old Nov 16, 2005 | 05:10 PM
AJay's Avatar
AJay
Old Nov 16, 2005 | 06:32 PM
turboc5's Avatar
turboc5
I used the ls2 pump. soposidly its better but they looked almost identical to me. I just ported my own. Take the steel cover off. Then on the inlet their is a piece of casting flash you could remove, and then round the edges of the outlet. I just used a dremil. Reinstall the cover and use red locktite on the bolts. Also you could put a 1/8" shim on the oil pressure return spring (in between the spring and the cap screw) and it will give you approx. 12 more psi. While your at it change to a ls2 timing chain as well. Much stronger.
To Ported oil pumps ?
