There is really only one way to do it "right" if you are at all concerned about flywheel/clutch balance: Take the flywheel, PP, PP bolts and washers to a good shop (the one I use can balance to 1/10th of a gram, closer than anyone could possibly need!) and have them zero balance the flywheel alone. Then have them attach the PP and rebalance to zero, removing/adding metal as needed on the PP portion only.
This way, if you have to change the PP in the future, you can have just it balanced, without being forced to re & re the flywheel as well.
Would you care to explain? Have you installed or driven a car with the Spec V clutch and billet flywheel? If no, then you don't know what you're talking about. Nevermind, i just looked through some of your posts to see what mods you have to your car.
let me tell you what a corvette tech and I discussed a few months back. Mind you he does JUST corvettes and seems very competent. I have done 99.9% of the work on my car and only brought my car in for warranty so I feel I am a good judge of competence. What he does is such:
He notes the spots on the stock flywheel that has weights on it. He marks those spots on the new flywheel he puts in. he does NOT put those weight on until after he test drives the car and noticed a vibration. THEN and on THEN, IF there is a vibration, he takes that black plastic cover off the front of the bellhousing (not the inspection plate) and inserts one weight at a time and repeats. With that said, my new LS7 setup didnt need any weights and I have no vibration or balance issues. Ditto w/ the LS6 clutch I put in last year. The way he does it, the H pipe does not need to come down every time you want to insert a balance weight.
Dave
Dave that's a fantastic way of doing it! However the fidanza aluminum flywheel doesn't have the holes on the backside to add the counterweights So it's better to just pull, match balance and re-install. BUT, for a factory flywheel w/ the holes that's damn smart.
www.cartek.net One of the fastest vendors on here that never speculates about speed. They just post up their results. Hell, half the time other people post their results for them. No promises, just reality with these guys. IMO, the three major tuners on this forum are Cartek, A&A, and ECS (in no particular order). All have the absolute BEST customer service.
I must be one of the lucky ones. I purchased a Spec 3 clutch and Fidanza aluminum flywheel and didn't have them balanced to old or just balanced. I don't have any vibration that I can tell.
Yes, I actually installed a brand new LUK Stage-II assembly that was guaranteed to be zero'd out. Then I got a rather annoying vibration. That clutch eventually broke and my rear main seal started leaking.
The Corvette tech mis read the LUK instructions ( you have to torque the pressure plate to the aluminum flywheel at a lower torque b/c the alum is softer) he torqued the flywheel to the crank at the lower settings and the bolts sheared off.
Fun ****.
Having read the widely different opinions on this subject I made some calls to local machine shops. The answer I got there was that they zero balance the components, and none have ever match balanced. Note that they may not have seen the particular problems that the members have seen.
I sent the shop that's been doing my engine work for years this thread, and they picked up on this statement above. His thought was that if the bolts were never torqued properly, you couldn't be sure what was causing your vibration, and that if the assy was properly torqued, you may not have had a problem. When I asked about your 8 gram out of balance that you measured, and re-introduced, he just said he's never heard of anything like that, and 8 gm is a mile off.
I'm getting cold feet on the aluminum flywheel install I wanted to do because now I'm going to be hanging the car up on a lift while the parts are in the machine shop to be checked. That just will not cut it the way I get my stuff done.
I called several machine shops, there were several that had absolutly no idea what I was talking about. I finally found a shop locally that balances race engines and they said no problem. I guess it takes a special type of machine such as a "Hines" or "Stewart Warner" balancer.
Look... I literally poured over the forums after getting into this issue. I called 21st century, A&A, Lingenfelter, MTI, ECS, and Cartek to talk to all the top of the line Vette tuners. All said that it can be a problem w/ LSX motors. They said that most are fine, but some can and do need a match balanced clutch. Seeing as how there's so much labor involved in the process I'd want to make sure mine's right.
Step 1 take stock clutch assembly to machine shop and have it spun up. If it spins out balanced then yuo're fine. But if not then you know it's off to compensate for the motor. It's really very simple.
I know for a fact that my stock clutch ended up being 8grams off and now after matching it the car is like stock again.
Talking to the tuners they always balance a clutch even when new b/c they're not always zero'd eventhough the mfgs say they're supposed to be. Some are as much as 40 grams out. This is comming from lingenfelter.
now it will be a matter of being able to tie a lift up while the original flywheel and clutch are at the machine shop - as Cobra points out, this isn't where you want to make a mistake. It sure makes the whole process a pain that this isn't a car that you can roll off the lift once you've started the job....
