I just bought 4 new Brembo, zinc coated, cross drilled rotors. The question is, do I need to replace the pads at the same time?
The pads are OEM with 14,000 miles on them. They still have plenty of meat, but did not know how they would seat to the new rotors.
Also does anyone have the web address to the directions to replace the rotors?
Thanks Neatnic
Most recommend that you always use new pads on new rotors to make sure they seat, and bed properly.
You can use your old pads, but will not get maximum braking
