Shifter started to vibrate !! Long post !!
It does have 410 gears that have never made a sound in 12 mos. Again the car was not abused only hard acceleration and by the way it really does accelerate
Any ideas????
Editing post........... I did not state the problem clearly. I don't feel the problem is with the shifter at all. It seems like something shifted during the hard acceleration and is causing the shifter to vibrate.. as you let on and of the gas it is like you can hear the ring and pinion, or tranny gear noise amplified thru the shifter. I will check underneath again today and then check the shifter... Thanks for listening
Recently I saw a B&M shifter that has this same rubber insulator made into the shaft. The guy behind the counter says B&M calls their "Sport" shifter, so maybe they are selling it in addition to their "Ripper" shifter which has the one piece shaft. You might look into it and see.
BTW, some ***** seem to be more prone to making noise than others. I have a one piece solid aluminum **** and sometimes on hard acceleration it makes a bit of a light buzzing noise too in certain gears. During normal driving it's usually quiet.
Check your shifter and make sure all the bolts are good and snug too. HTH
