lowering your vette tell me why
Old Nov 20, 2005 | 01:30 PM
road dog's Avatar
road dog
Default lowering your vette tell me why
Will lowering your vette change the center of gravity and if so for better or worse and is it more for looks or preformance I fiigure it was designed that way for a reson why change it.
98 torch red coupe
6 speed manual
Old Nov 20, 2005 | 01:38 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
let's see if we get any autox or track guy in here, most of the time it's for looks
Old Nov 20, 2005 | 01:39 PM
Nathan1234's Avatar
Nathan1234
Anybody ever watched to video that tells how to adjust it? It should probably also say why you would want to (in GM's opinion).
Old Nov 20, 2005 | 01:55 PM
Z06Doug's Avatar
Z06Doug
It's for looks more often than not. It does slightly lower the center of gravity, however unless your an expert driver you won't notice the difference or be able to utilize it.
Old Nov 20, 2005 | 02:08 PM
mixermike's Avatar
mixermike
it looks
Old Nov 20, 2005 | 02:31 PM
TheLaserShop's Avatar
TheLaserShop
98 torch red coupe
6 speed manual
Changed the livin' crap out of my car. Thats what makes it my car.
Old Nov 21, 2005 | 11:09 PM
striper's Avatar
striper
However slight one may think, lowering will affect the handling in a positive manner.
Old Nov 21, 2005 | 11:10 PM
EHS's Avatar
EHS
What kind of crap did it change, exactly?
Old Nov 21, 2005 | 11:17 PM
vms4evr's Avatar
vms4evr
In the Z06 owners video it says lowering for track use. But I'll bet more people lower for looks than function. Regardless of your reason just make sure you you keep the natural rake of 1/2-3/4 higher in the rear. Do get an alignment after about a week when the suspension has finished settling.
Mine is lowered on the stock bolts for track use but it does also look better.
Old Nov 21, 2005 | 11:52 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
looks here. Tried longer bolts, and it was too low. The car launched at the track a bit better with a west coast stance, but lower. Back to stock bolts, 4 threads on each as all the way was still to low. Too easy to do at the house, well the rear is for sure, and it does look much better.
Dave
Old Nov 22, 2005 | 12:58 AM
JETZ's Avatar
JETZ
Cause I don't like the dorky 4X4 look!
Old Nov 22, 2005 | 01:49 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Originally Posted by mixermike
it looks
Old Nov 22, 2005 | 02:49 AM
bglmn's Avatar
bglmn
My man, if you gotta ask why, then maybe you shouldn't do it.
Does yours look like a "4 X 4"? I didn't think so, either.
Maybe it's just because I'm middle-aged, but I don't get it. I
just let these forum member talk me into it.
Now I'm constantly bottoming out, abusing the hell out my fenders and underbody, and always touching up the paint. For what?
Do what ya gotta do, but do it because it's what YOU want.
Old Nov 22, 2005 | 02:55 AM
2MuchRiceMakesMeSick's Avatar
Looks here also.
I guess I like rougher ride too
Old Nov 22, 2005 | 05:44 AM
Slammed..'s Avatar
Slammed..
Keep in mind GM has to make sacrifices.They have to make it so the average driver can get in and out of extreme angled driveways etc..
Theres better intakes and exhaust systems too,once again,GM has to comprimise,goverment noise restrictions,etc.Just because the c5 came a certain way,doesn't mean GM couldn't make it better.
Old Dec 2, 2005 | 02:16 PM
kdwhite's Avatar
kdwhite
Dr. Erik Strelnieks, SCCA SS autocros champion several times, recommended I lower my ZO6 to setup for autocross. I'm doiong it this weekend and then following up with a cusotm alignment.
I don't know how much difference this will make, but it is hard to argue with the advice of success!
Old Dec 2, 2005 | 02:59 PM
Mikelly's Avatar
Mikelly
Most people lower the car for looks and quite honestly, it is simple to do, but also simple to screw up the handling of the car if you really drive it hard on the street.
Regardless how much you lower it, keep in mind GM factored in a certain amount of rake front to rear to maintain the aerodynamic handling of the car. You can really jack up the handling of a C5 by not following the guidelines in the shop manual on the rake.
Mike
To lowering your vette tell me why
Old Dec 2, 2005 | 04:34 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
lower CG but don't slam it the suspenion won't work properly.
Old Dec 2, 2005 | 05:04 PM
Goonie's Avatar
Goonie
EG needs to chime in on this thread!
Old Dec 2, 2005 | 08:12 PM
Dark-Knight's Avatar
Dark-Knight
Certainly does look better lowered!
